Holding Slab/poured Curb Together
looked at a garage rebuild yesterday that had a tree fall on it and homeowner tore it all down....he just wants a new shell erected and finished off-nothing to do with slab.
Slab is a typical 3" thick with integrated raised curb around perimeter wide enough for a 2x4 and about 3" higher than slab surface that the 1 day garage builder hacks use. And like all the typical poured curb slabs for garages in this area it's got cracks in it. Slab itself did not get any cuts (24x22) so it spiders across the 24' side and goes into both sidewall curbs where it's pulled apart about 1/2", then it cracked going the other direction so back wall also has a 1/2" crack where poured curb is splitting apart. I told him if he wanted my warranty I would have to come in and remove all of the concrete and pour new since this was not going to last...typical customer of mine-he wants to leave it to save money. I just dont want to build this and have it start to sag over time...naturally I will type up a waiver for him to sign, but is there a quick cheap fix I could propose to this guy to help slow down the splitting of the slab/curb so new garage wont look like ass 6months after we leave?? I've seen and rebuild many garages with this type of concrete slab so I know exactly how bad this one will get but ya cant argue with a cheap homie and I'd rather make money than turn it away and have him sign a waiver acknowledging I tried to explain what would shappen so wwhen it does, he cant say it was me. |
Trade: underground
Re: Holding Slab/poured Curb Together
there's not much to hold together with a 3" thick slab. that's barely enough to properly cover the reinforcement (if there is any).
If the old slab is failing because the ground beneath it is weak then removing it and pouring new isn't really getting you anywhere. If it's just crappy concrete atop structurally sound earth then you might have OK results pouring a sufficiently thick and reinforced slab over the old and doweling the old slab into the new. I realize that doesn't qualify as "a quick cheap fix" but it does eliminate the demolition and disposal process.
Fortunately I keep my feathers numbered for...for just such an emergency. -Foghorn Leghorn |
Sadly there is no "right way" to fix this since it's a typical "area customer" that does'nt have the funds to do the entire thing correctly. I hate to build on this shoddy slab/curb BS even after I have him sign a waiver acknowledging the garage will sink/buckle...aka look like sheeot in a short time, and he knows that from our meeting Sunday and naturally is fine with that
The only solution I can see is to build a pole barn just outside the slab and work from there. That way, his crap slab is just a floor, and your structure will be supported on the poles. A little more expensive, but not so much as removing and repouring his slab.
#5 | |
Re: Holding Slab/poured Curb TogetherQuote:
I'll take your word on the cost, but I would should rather do that than have to remove/replace the slab. The savings in time alone should be worth somehting.
#7 | |
Lotta dicken around getting a pole barn ready for a regular roof and regular siding which outweighs any time saved with a remove/repour..actually I think time savings is in favor of the repour since for garages under the 850sqft footing requirement dont take very long to set-up and pour, most are completely done in 5-6hours, we'd have that much time tallied up with all the little things in a pole barn trying to make it look like a neighborhood garage.
No mesh or bar <shakes head>... Again, I will take your word on it, since every pole barn I have worked on was simply sheathed in tin, and even the big 6 bay ones go up in a day or 2.
| holding company | Rae | Business | 7 | 07-18-2007 07:49 AM |
| Concrete Curb and Gutter Costs | stevem | Masonry | 8 | 03-20-2007 06:32 PM |
| holding tank | MarcM8181 | Plumbing | 2 | 08-17-2006 06:08 PM |
| Poured rasied curb vs block for garage-opinions | IHI | Masonry | 7 | 08-02-2006 11:16 PM |
| curb machine ques | jmon12 | Excavation & Site Work | 5 | 02-23-2006 03:22 PM |
