High Temperature Masonry Adhesive?
Old 09-23-2010, 06:40 PM   #1
xhibit4's Avatar
Built a fire pit/place out of stone on property, capped with Flagstone, rear wall pieces adhered fine but sides and front did not. Removed the loose pieces, substrate is perfectly level with no holes or indentations. Do not want to remove mortar and start over, just want to lay a bead of something that will withstand the temperature and adhere to both surfaces. Quikcrete makes a fireplace mortar in a caulk tube but was told by Manufacturer it was not for my application. Any suggestions?
xhibit4 is offline
Old 09-23-2010, 07:20 PM   #2
NJ Brickie's Avatar
Trade: Bricklayer
Rewards Points: 750
Re: High Temperature Masonry Adhesive?
Cultured stone is not meant to be installed in a fire pit. You need to start over completely. Not just the stones that fell off.
NJ Brickie is offline
Old 09-24-2010, 04:34 AM   #3
Stonemason
bytor's Avatar
Trade: masonry
Rewards Points: 602
Years ago I contacted the technical department of one of the 'thinset' manufacturers . They assured me that their product would be acceptable in a high heat environment (the un-modified variety).... never did try it out though...
bytor is offline
Old 09-24-2010, 07:14 AM   #4
xhibit4's Avatar
The firepit is 10' w X 4' L X 4' high sitting on a 10 X 4 slab, bottom is lined with dry fitted half thickness firebrick, there has been no problems with the fire ( and they are monster fires) hitting the back wall attached Flagstone nor was there any issue with the Flagstone that needs to be re-attached. It looks like a big couch so the heat is not concentrated.
xhibit4 is offline
Old 09-24-2010, 07:40 AM   #5
xhibit4's Avatar
Thanks,doing a bathroom with Schluter system membrane so I have Lacrete Megabond, have to give them a call.
xhibit4 is offline
Old 09-24-2010, 08:33 AM   #6
Tscarborough's Avatar
Rewards Points: 1,392
I have used several brands and types of thinset in high temp applications (>500 degrees) and they all failed. There are several types of refractory cement available, any of the dry types will work. Insulstick is probably the best for your application.
You can make your own, 1/1/1/3, portland/lime/fireclay/very fine silica sand.
Tscarborough is offline
The Following User Says Thank You to Tscarborough For This Useful Post:
bytor (09-25-2010)
High Speed Cable & P.O.T. Separation? redzthredz Low Voltage 11 12-01-2009 05:09 PM
How to Seal White Mortar Masonry ScottLewis Masonry 2 03-21-2009 07:50 PM
removing doorway from solid masonry wall Jamison Remodeling 3 08-15-2008 06:23 PM
Houston Area Builders and Project Mgrs- Are you prepared for high tech homes HomeMedia Pros Business 10 02-19-2008 02:43 AM
Anyoen build 8 ft high masonry steps? ruskent Masonry 7 02-13-2007 09:15 PM
