Help Find Brick
Old 10-15-2008, 07:28 AM   #1
jrtornow's Avatar
Trade: General Contractor/ Builder
Help Find Brick
I am in desperate need of finding a certain type/color of brick for a repair job on a post office. Anyone know where to start looking?
jrtornow is offline
Old 10-15-2008, 07:58 AM   #2
Money Changer
bert0168's Avatar
Trade: Residential Remodeling
Re: Help Find Brick
Take some out of the wall around back where nobody will see it
bert0168 is offline
Old 10-15-2008, 09:17 AM   #3
concretemasonry's Avatar
Trade: Masonry consultant
Re: Help Find Brick
Knock out and grab a few brick as samples and go to your local brick dealer. He should be able to steer you in the right direction or come up with a close match.
Dick
concretemasonry is offline
Old 10-15-2008, 01:47 PM   #4
stacker's Avatar
Trade: masonry
Re: Help Find Brick
if that is not possible,call your brick company and they most likely will send a salesman right out.but i agree the best would be to take a couple brick to the company directly.
also since you have a computer,get on the sites of local brick companies in your area....ie acme brick.com
stacker is offline
Old 10-15-2008, 03:00 PM   #5
Tscarborough's Avatar
Re: Help Find Brick
Since this is what I do most of the day, let me give you some ideas.
First, don't expect me to come to your job to match brick when you need a couple of hundred brick. Bring the brick, not a picture, to me and I will help you find something to match or the closest available.
Matching brick from a picture is like picking a paint color over the phone.
If you only need a few, like a window infill or a damaged corner, look for areas of the building that are not visible. In older buildings, you can often get plenty from the attic spaces or from the interior wythes of planters.
If it is a veneer (i.e. modern) construction, search the grounds for bed borders, walkways or a pile behind the shed. Leftover brick are often left on the jobsite.
If you need a fair amount, but less than 10,000, you will most likely have to go with an in stock product. Find the closet match you can, in particular the exact size, then salvage and blend, rebuilding to corners or other visual breaks.
If you need more than 10,000 you can generally get a close match, given time and money.
Tscarborough is offline
Old 10-18-2008, 01:39 PM   #6
carolinaprowash's Avatar
Trade: Exterior Surface Specialists
Re: Help Find Brick
Put a close type brick in then color it to match
Carolina ProWash
Graham, NC 27253
336-270-4598 Office
336-516-6139 Roger 336-516-6356 Celeste
carolinaprowash is offline
how do i price pointing brick??????? USER8493893 Masonry 22 11-26-2011 04:25 PM
Historic Brick Fireplace Tommy C Masonry 11 10-04-2009 10:33 PM
Question on Residential Brick Veneer Tommy C Masonry 12 09-14-2008 08:29 PM
Stone and Brick Combination Hardibuilt Business 3 01-23-2007 04:17 AM
Braking metal for a brick exterior? Luke's Dad Windows, Siding and Doors 8 01-07-2007 06:59 AM
