Help With Bluestone Staining
Old 06-14-2008, 04:31 PM   #1
eekie34's Avatar
Trade: Masonry restoration
I recently installed a bluestone patio on an elevated slab of concrete. After about one week, I started to notice some efflorescence which disappated after a few weeks. All around the joints stayed damped, but what is making it look bad is some sort of water stain looking leftover around the perimeter of most of the stones. It looks like water wicking and a halo around the stones. I assume this may be mineral deposits as well? any suggest how to clean or get rid of them?
eekie34 is offline
Old 06-14-2008, 05:29 PM   #2
genecarp's Avatar
Re: Help With Bluestone Staining
hi, welcome to the site
genecarp is offline
Old 06-14-2008, 11:49 PM   #3
ameliapearn's Avatar
Trade: Bill Pearn Masonry
Do you have a photo?
ameliapearn is offline
Old 06-15-2008, 07:03 AM   #4
eekie34's Avatar
Not off hand. The joints were struck concave, and when it rains, the joints are always the last to dry out, and the moisture is wicking from the joints into the edgers of the stone and it continues to travel thru the stone. when it dries out, it leaves what i think is a hard water stain around the edge of the stone. Looks great wet, but not so much with this staining.
eekie34 is offline
Old 06-15-2008, 08:16 AM   #5
artisanstone's Avatar
Trade: Stonemasonry
Check out this site. http://www.pavingexpert.com/cgi-bin/ib3/ikonboard.cgi
There is discussion there about this problem, commonly called "picture framing".
artisanstone is offline
Old 06-15-2008, 12:18 PM   #6
eekie34's Avatar
any cleaners or solutions to this problem that anybody knows of? I am eventaully going to install a roof over, but I want it to look goos.
eekie34 is offline
Old 06-15-2008, 12:27 PM   #7
Tscarborough's Avatar
Get it clean and dry and seal it and it should solve the problem.
Tscarborough is online now
Old 06-15-2008, 02:11 PM   #8
CJKarl's Avatar
Trade: Masonry
Were the joints clean to begin with. How wet was your mortar when you jointed them off?
There's Always A Market For Quality
http://www.kaufmannmasonry.com/
CJKarl is offline
Old 06-15-2008, 05:24 PM   #9
eekie34's Avatar
joints were clean, and used a dry pointing mix that had enought water to be able to ball the stuff up. Wont a sealer trap in any moisture coming up thru the slab?
eekie34 is offline
Old 06-15-2008, 05:43 PM   #10
Not if you use the proper one. Something like Prime-A-Pell by Chemprobe or some of ProSoCo's sealers will allow vapor transmission, but not liquid water absorption. I do not recommend Prime-A-Pel for horizontal applications, though. I recommend ProSoCo SiloxanePD:
http://www.prosoco.com/ProductDetail.asp?ID={D113DB5A-0836-4C51-822E-B0006E080476}
for porous stone (I am not familiar with bluestone, but assume it is a sandstone or limestone).
Old 06-15-2008, 05:48 PM   #11
eekie34's Avatar
That's what i use to wp the chimney work I do. But how do i get rid of those stains, or will they always stay there? Should I clean it will 600 cleaner first?
eekie34 is offline
Old 06-15-2008, 07:06 PM   #12
600 is for new construction mortar, not this type of stain. Without looking at it and feeling it, I can't be sure which one will clean it, but my best guess would 101 Lime Solvent.
Old 06-15-2008, 07:33 PM   #13
eekie34's Avatar
thanks. i'll try the 101 first
eekie34 is offline
Old 06-15-2008, 07:37 PM   #14
Better to determine what the stone is and what the stain is, first. What is the stone, and is the stain hard and white, chalky and white, or something else.
Old 06-15-2008, 07:41 PM   #15
eekie34's Avatar
the stone is pennsylvania bluestone. the residue was white at first and disappeared. what was left has been desribed as pictureframing on concrete pavers, with a dark like water stain remaining when the patio dries.
eekie34 is offline
Old 06-15-2008, 08:03 PM   #16
OK, I looked it up. It is most likely a sandstone, which means the SiloxanePD is fine. You will need to determine if the stain is soft and chalky or hard, although I suspect soft. If so, then use something mild like diluted CLR, dry to a 24 hour moisture test and seal.
Old 06-15-2008, 09:52 PM   #17
CJKarl's Avatar
Trade: Masonry
Another question eekie34, did you use any bonding agent in the joint mix? Sometimes I've seen joint mortar with bonding agent leave a slight discoloration around the joints.
Almost like it seeped outward from the joint.
CJKarl is offline
Old 06-16-2008, 03:33 PM   #18
eekie34's Avatar
whats clr? I have a picture, but i don't know how to attach it to the site. computer novice. it keeps telling me it is too big to upload.
eekie34 is offline
Old 06-16-2008, 06:59 PM   #19
CLR is a hard water stain remover. It is available at most hardware stores, and probably Homeless Depot and WallofChinamart too.
Old 06-16-2008, 07:51 PM   #20
custom patios's Avatar
Trade: masonry, hardscape
cleaning may work but your biggest problem is the pointing. it is not recommended to strike concave joints for flat work. the patio's integrity is jeopardized by water infiltraion. you really should grind the joints and repoint them flush. a big pita, but i will work. also what mix ratio did you use for pointing.
custom patios is offline
railings and columns on bluestone kylemfk Decks & Fencing 3 04-18-2007 05:08 PM
deck staining bigdawg Painting & Finish Work 9 03-06-2007 01:25 AM
Staining Rough Cedar lpp Painting & Finish Work 12 05-05-2006 10:45 PM
Staining interior Cherry trim cowtown Painting & Finish Work 8 04-25-2006 09:41 PM
Water staining on exterior stucco cutnroller Painting & Finish Work 13 03-17-2006 05:22 PM
