Guy Made These By Hand - Masonry - Contractor Talk
Old 12-05-2017, 05:51 PM   #1
JBM's Avatar
Trade: Masonry
Rewards Points: 5,432
Im starting a chimney and a guy made these trusses (and all kinds of other beam work will be coming) by hand. Wish I got back before they were set
JBM is online now
The Following 4 Users Say Thank You to JBM For This Useful Post:
hdavis (12-06-2017), jlhaslip (12-05-2017), rblakes1 (12-05-2017), Rio (12-07-2017)
Old 12-05-2017, 05:53 PM   #2
JBM's Avatar
Trade: Masonry
Re: Guy Made These By Hand
Dont know why one is croocked, its not crooked on my phone lol
JBM is online now
Old 12-05-2017, 06:19 PM   #3
tjbnwi's Avatar
Rewards Points: 4,928
Click on it twice, is straightens.
tjbnwi is online now
The Following 3 Users Say Thank You to tjbnwi For This Useful Post:
JBM (12-05-2017), KAP (12-05-2017), MarkJames (12-06-2017)
Old 12-06-2017, 01:57 PM   #4
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 6,843
Jungle rules between subs? Or roll your own self General contracting by owner?
Blue Prints and a schedule......
CPM: Critical Path Method, File flight plan, fill tank, check plane out, then take off.....lower landing gear BEFORE landing....Etc.......
Tough to make money laying around wood beams you can't get dirty....Maybe build behind the truss stone veneer in panel(s) on ground/ or scaffold/ lower chimney base, Forklift/roll into place.
I'd try to lay it over wall with a helper/ apprentice on the other side of the for final positioning.
The timber rafters sans collar tie is nothing but trouble.
Is it me, or is the 90 degree angle a rare bird on this house? ICF is very hard to keep in spec plumb wise. Might be cell phone optics....
And as usual I see cubic yards of toxic smoke producing combustible insulation INSIDE the House.....why even go there? When will hybrid forming be considered bare minimum with foam forming residential?
Foam exterior walls aren't any more fire resistant, but, occupants on lower floors have some chance of survival, see Welfare Tower fire in England, ~50 dead.
Good Luck.
Fouthgeneration is offline
Old 12-06-2017, 04:07 PM   #5
rustyjames's Avatar
Rewards Points: 1,580
Quote: "Blue Prints and a schedule......"
Blue prints? I'm a pretty old man and never seen them on any job I've ever worked on. Us oldtimers call them drawings.
rustyjames is online now
Old 12-06-2017, 07:36 PM   #6
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 2,623
Dang sonny, I must be a candidate for mummy rags then. I recall using them in the 70's.
Gotta admit it's been a coon's age or two since I heard the term though.
Tinstaafl is online now
Old 12-06-2017, 10:00 PM   #7
JBM's Avatar
Trade: Masonry
Prints lol. They poured the butting walls today with 5 rows of steel sticking out without bent ends, without a stamp or consult.
JBM is online now
The Following User Says Thank You to JBM For This Useful Post:
Fouthgeneration (12-08-2017)
Old 12-06-2017, 10:44 PM   #8
rustyjames's Avatar
I was just a flunky back in the seventies, they kept the "prints" locked up for the important people to look at
The Following User Says Thank You to rustyjames For This Useful Post:
Tinstaafl (12-06-2017)
Old 12-07-2017, 02:39 AM   #9
Sure, I can do that...
jlhaslip's Avatar
Trade: carpentry/renovations
Rewards Points: 190
Collar Ties are not required for this design of a King Post Truss.
If you have a look, there are 6 - 3/4 inch pegs holding the top ends of the rafters to the king post. Collar ties are used to prevent separation at the top of rafter pairs. It isn't going to happen on this truss configuration.
jlhaslip is offline
Old 12-07-2017, 09:06 AM   #10
rustyjames's Avatar
I think 4th is referring to that large upper roof section, I don't see any ties on that.
Old 12-07-2017, 09:18 AM   #11
Capra aegagrus
Tinstaafl's Avatar
No need for collar ties there, either. The first floor ceiling joists serve that purpose.
rustyjames (12-07-2017)
Old 12-07-2017, 09:38 AM   #12
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 4,778
Technically, they serve different purposes. The ceiling joists resist rafter thrust from gravity loads. Collar ties, or some sort of detailed connection at the ridge, resists wind uplift. An important distinction.
Golden view is online now
The Following 2 Users Say Thank You to Golden view For This Useful Post:
rustyjames (12-07-2017), Tinstaafl (12-07-2017)
Old 12-07-2017, 04:12 PM   #13
JBM's Avatar
Trade: Masonry
They may yet still put ties in the main house as they are still framing it.
JBM is online now
Old 12-08-2017, 06:37 PM   #14
Renaissance Man
superseal's Avatar
Rewards Points: 5,586
So many people confuse this issue...metal straps over the ridge perform the same duty.
supersealconstruction.com
superseal is offline
Old 12-09-2017, 11:11 AM   #15
fjn's Avatar
Trade: mason
Rewards Points: 9,560
Just to throw my .02 in. Collar ties in order to be effective and meet code,need to be in the bottom 1/3 of the span. So,in effect,ceiling joists can and often do meet that requirement. Examples I can think of where there is not a need for collar ties are,trusses as shown and a structural ridge . Obviously,light 2 x ridges while they may be thought of as structural,are in essence not. One of the purposes of collar ties is to resist the thrust of the rafters exerting lateral pressure on the walls.
fjn is offline
parkers5150 (12-09-2017)
Who still hand drives? CJ21 Carpentry 201 12-14-2013 02:18 PM
Porter Cable Millworker Tools & Equipment 55 11-01-2013 05:42 PM
spotty adhesion Pete'sfeets Painting & Finish Work 7 05-15-2013 09:54 PM
Hard earned money on foreign made tools (RANT) Irishslave Tools & Equipment 45 07-09-2010 12:01 AM
American Made wallmaxx Tools & Equipment 13 11-24-2008 06:16 PM
