Trade: interlocking pavers and Premier Deck builder
Grinding Concrete
Hey guys we recently poured a slab around a pool a week ago. However it turns out that we have a high spot that is holding water. I am wondering if anyone has ever grinded concrete before and what wo watch out for.
Any help would be great Thanks |
Re: Grinding Concrete
High spots generally shed water. Are you going to surface the deck, or is what you have going to be the finished product.
Thanks for the reply
Well see the thing is that the is a high spot in the area and direction that the slope should be so it is holding onto some water here. We intend after grinding on putting some sort of coating on it. If anyone can help with what to expect that would be a lot of help Thanks again Last edited by InterlockPavers; 06-18-2006 at 11:12 PM. |
If you have the room, build with self leveling concrete, Grinding is a mess.
King of Caulk
Trade: If you wanted it done by a professional, why did you call me?
grinding will be messy, the problem will be blending what was ground into what was not. The grit disks they sell everywhere work well. But Serious dust. Major dust, huge. You may be able to get one of those terrazo grinding machines at the rental yard.
Or you could cut around it, bush/chip out to a good depth. then repour.
You want absolutely security? You want to be totally protected against terrorism? I have a proposal for you: A one way ticket to Panmunjom in North Korea. Guarantee you, they have absolute security. You will have absolute protection against terrorism. There is no terrorism in North Korea except the terrorism, of course, that is wielded by the state itself. Because there is no privacy, there are no constitutional rights, there is no freedom. But you've got security. Ted Koppel |
Trade: General Building Contractor
It depends on how much material you need to remove. If it is not too much, you should carefully mark out where the problem is. I then use a diamond blade in a skilsaw set to about 3/8 inch depth and start cutting lines about 3/4 inch apart. After making a bunch of parrallel lines in the marked out area, I use cold chisels and even a wide brick chisel to break out the concrete between the cuts. A lot of the bulk material is removed that way. I then use a Bosch 5" concrete surfacing grinder (1773ak) with a vaccuum. That tool is pretty effective if you are careful. Repeat where necessary. If you over-do it, there are products that you can use to blend everything back into the rest of the slab. It is a messy job. I sometimes use water, rubber boots, and a GFCI with the saw-cutting part to keep the dust down.
Trade: Masonry / architectural stone carving
Also, if it is not too big of an area, Makita makes a pretty nifty "concrete Planer" . It will take your high spot down, and it comes with a dust collecting bag, (like on a belt sander) to help cut down on the mess. The cutting tool is a 4 inch diamond cup wheel.
JVC Link http://www.mytoolstore.com/makita/mak05-04.html Last edited by jvcstone; 06-19-2006 at 05:01 PM. |
Some sort of coating?
thanks guys i appreciate all the help and information you are giving me here.
I must say this forum is a great place for all contractors. Some sort of coating? YEa I was gonna coat the whole entire patio surface with a product that will hide some discrepencys. This is the first concrete job we did. It wasnt the worst nor the best. But I just wanna make the homeowner as happy as possible. Thanks again guys. Any other suggestions are greatly appreciated. |
#10 | |
Re: Grinding ConcreteQuote:
No I m not the homeowner. However this was done for a friend and was very low cost. We were just trying to figure an easy fix if possible. We grinded and left them with nice smooth slab. Rented concrete grinder.
Worked woners but it took time. Thanks for all your help |
| Fiber Optics in concrete countertops | 6stringmason | Concrete & Paving | 17 | 03-16-2011 05:49 PM |
| Staining concrete | ryan.s | Masonry | 12 | 03-05-2009 03:54 PM |
| Concrete home | denick | Concrete & Paving | 5 | 03-06-2007 04:32 PM |
| Paint on concrete - Grinding or blasting? | Minuteman | Flooring | 7 | 09-15-2006 01:04 PM |
