Going To Build This...
Old 04-09-2008, 09:06 PM   #1
CJKarl's Avatar
Trade: Masonry
...but not sure how to do it yet.
There's Always A Market For Quality
http://www.kaufmannmasonry.com/
CJKarl is offline
Old 04-09-2008, 09:08 PM   #2
CJKarl's Avatar
Trade: Masonry
Re: Going To Build This...
Here's where I am. Doing the corners and starting the piers tomorrow.
CJKarl is offline
Old 04-09-2008, 09:11 PM   #3
CJKarl's Avatar
Trade: Masonry
I'm thinking I have to build some kind of masonite or flexable material falsework. It has to built AROUND the piers and then removed later. I've been tweeking my brain all the way up with this chimney. Now it's time to pay the piper.
Any thoughts?
CJKarl is offline
Old 04-09-2008, 09:19 PM   #4
master mason's Avatar
Trade: masonry
looks great CJ. I hate those 3 holed brick,the mud has to be stiffer than I like it cuz it falls in the big holes.I like my brick mud like velvet.
master mason is offline
Old 04-09-2008, 09:21 PM   #5
lukachuki's Avatar
sorry no solutions...but keep us posted with pictures. Looks like a real challenge. I like the detailing but I can see how it would be making you sweat a little.
"The problem with internet quotes is, you never know if they are authentic." -Abraham Lincoln-
Less with the jaw more with the paw!
lukachuki is offline
Old 04-09-2008, 09:23 PM   #6
CJKarl's Avatar
Trade: Masonry
You ain't telling me nuttin. Those things EAT mud...but once they set, they don't come apart.
CJKarl is offline
Old 04-09-2008, 09:27 PM   #7
wesmartyn's Avatar
Trade: Brick and Stone m
That looks sweet.
But where is the air space?
wesmartyn is offline
Old 04-09-2008, 09:30 PM   #8
6stringmason's Avatar
Trade: masonry
Looks great!
I would say for your arches on top where they hang over a bit, maybe make up some sort of jig that rests on the part youre on now that sits along the columns you have to build and holds the arched brick in place.
Then maybe to keep the jigs in place and held tight to the columns wrap a small ratchet strap around em and cinch em tight. Im thinkin a few 2x's and some 1/2" osb or something.
Just an idea.
If you dont understand what I just wrote (because I wouldnt) I can try and draw a picture and post it for ya?
Kamps Masonry & Concrete Countertop Design Green Bay, WI
920-680-3195
Visit our website @
http://www.concretecountertopsdesign.com/
6stringmason is online now
Old 04-09-2008, 09:32 PM   #9
Trade: masonry
CJ, you need to put a piece of plywood over top the flues and build your form up off of that.I would also dowel a #4 rebar in each pier and lay the brick over them and fill the holes w/mud. This will sturdy up the piers
Old 04-09-2008, 09:34 PM   #10
Tscarborough's Avatar
I see issues.
Tscarborough is online now
Old 04-09-2008, 09:41 PM   #11
Trade: masonry
Do you have solid brick for the ends of the barrel arch?
Old 04-10-2008, 04:59 AM   #12
CJKarl's Avatar
Trade: Masonry
I do have solid brick for the ends. On those I'm going to drill about 3/4 into the brick and epoxy threaded stainless rod about 1 ft long into them. Then when I lay the next 3 or 4 courses I'll slid the rod through those wopper brick cores and either epoxy or grout them. I also talked the owner into letting me stucco the underside of the arched cap with black mortar so I don't have to worry about any joint detail on the underside.
CJKarl is offline
Old 04-10-2008, 05:01 AM   #13
CJKarl's Avatar
Trade: Masonry
Originally Posted by wesmartyn View Post
That looks sweet.
Airspace? Around the flue. Never do, never had any problems.
CJKarl is offline
Old 04-10-2008, 05:04 AM   #14
CJKarl's Avatar
Trade: Masonry
Originally Posted by Tscarborough View Post
I see issues.
CJKarl is offline
Old 04-10-2008, 08:58 AM   #15
The issue I see is that you have an un-buttressed arch. Unless you assemble it as a tensioned unit, it is going to want to flatten out and push the sides with it.
Old 04-10-2008, 04:37 PM   #16
bobcaygeonjon's Avatar
Trade: Bricklayer / contractor
I know it would cause a whole set of other problems but how about forming the arch on the ground use epoxy resin and re-bar through the holes and then hoisting up in one piece. Not that I have done anything like that before but I agree with tscarborough.
Btw, your scaffold scares me
bobcaygeonjon is offline
Old 04-10-2008, 05:39 PM   #17
CJKarl's Avatar
Trade: Masonry
Really? Never built an A-frame?
CJKarl is offline
Old 04-10-2008, 05:41 PM   #18
CJKarl's Avatar
Trade: Masonry
I'm going to run stainless threaded rod through the cores and do a "shade tree" post tension system.
CJKarl is offline
Old 04-10-2008, 05:55 PM   #19
CJKarl's Avatar
Trade: Masonry
THis is all we got done today, between the owner and the artichoke changing poop. But we're ready to try the arch tommorrow.
CJKarl is offline
Old 04-10-2008, 05:56 PM   #20
CJKarl's Avatar
Trade: Masonry
By the way...the dome came in today for the light shaft.
CJKarl is offline
Why Build ICF monsterconstruc Green Building 32 09-28-2008 11:48 PM
sprayer won't build pressure/ Traditions Painting & Finish Work 10 05-27-2007 09:12 PM
pricing a build out lowell5slide Construction 0 12-28-2006 11:39 PM
Cost to build in So Cal? Grunt General Discussion 1 10-14-2005 04:46 AM
