Gluing Cinderblock Walls With PL Premium?
Old 10-05-2017, 09:07 PM   #21
TimNJ's Avatar
Rewards Points: 2,606
Re: Gluing Cinderblock Walls With PL Premium?
I used PL on my some landscape blocks and this year they are 10 years old.
Some of them have failed this year.
TimNJ is online now
Old 10-06-2017, 11:16 AM   #22
Windycity's Avatar
Trade: Masonry
Rewards Points: 5,746
The blocks or the glue?
Years ago I had to demo a landscape block wall that was held together with glue and I will say the glue was so strong it actually ripped the material off the block instead of the glue failing. It actually peeled the block material from itself before the glue bond gave way...pretty strong chit
Windycity is online now
The Following User Says Thank You to Windycity For This Useful Post:
SmallTownGuy (10-06-2017)
Old 10-06-2017, 03:55 PM   #23
TimNJ's Avatar
The glue.
It is on some of the bull nose pavers at the end of my walkway.
Not all, just a couple here and there.
TimNJ is online now
The Following User Says Thank You to TimNJ For This Useful Post:
Fouthgeneration (10-06-2017)
Old 10-07-2017, 09:15 PM   #24
Doug1987's Avatar
Rewards Points: 20
Originally Posted by Fouthgeneration View Post
Doug 1987 : Running bond= One on top of two, vs stack bond is one on top of one...... half blocks needed for running bond jambs.....
Its a running bond.
Doug1987 is offline
Old 10-18-2017, 12:00 PM   #25
johnnyN's Avatar
Trade: Architectural Precast Concrete and Cast Stone
Rewards Points: 8
apart from the problem with leveling the bricks, using PL premium would be better.
That glue is amazing. It is now commonly used in the masonry industry because it is so good.
But you really cant use a grout gap.
Also because there is no play, you can't level things when the substrate is crooked.
johnnyN is offline
Old 10-26-2017, 04:38 PM   #26
Master Mason
RacinMason's Avatar
Trade: Masonry
Rewards Points: 110
If this is a business structure (kennel) wouldn't there be building inspections? I can't imagine that passing any codes
650cc on the track
800cc on the snow
1000cc on the street
RacinMason is offline
Old 11-08-2017, 07:56 AM   #27
phxmason's Avatar
Trade: Masonry
Did they use a footer? Rebar? Grout cells? obviously no way to use ladder wire. A lot of guys wanna impress the wife and go look **** up on pinterest go build something unsafe then drink a beer and consider themselves d.i.y. kings. One strong wind and you could have a lot of new doggies going to heaven.. Masons use footers and reinforcing specific to every wall for a reason.
phxmason is offline
Helped a friend build some walls wallmaxx Carpentry Picture Post 8 07-09-2012 09:22 PM
What is the max distance for load baring walls in a residence? kgcaddesign Architecture & Design 13 06-03-2012 02:35 PM
Non load bearing walls, 10 Ft. high ? HmBuilder2 Framing 5 08-25-2011 01:44 PM
Tall walls (2-storey walls) Zoltar Framing 21 03-11-2009 12:00 AM
Floating Basement Walls McMasters Framing 15 08-26-2008 10:43 PM
