Glueing Manufactured Stone
Old 04-09-2008, 05:19 PM   #1
6stringmason's Avatar
Trade: masonry
I have a job coming up to do a zero clearance fireplace in a drystack owens corning brand stone.
The backing is cement board. Im wondering if we can just use a product like liquid nails or similar caulk tube product to glue the stone on to the cement board?
I spoke with tech support guy from Owens Corning and they said they would not do that, but I have a hard time seeing why not. They wouldnt give a reason why they wouldnt, they just said no.
Any ideas on this type of installation, or recommendations?
Kamps Masonry & Concrete Countertop Design Green Bay, WI
920-680-3195
Visit our website @
http://www.concretecountertopsdesign.com/
6stringmason is offline
Old 04-09-2008, 05:55 PM   #2
genecarp's Avatar
Re: Glueing Manufactured Stone
moisture, never glue to cement board
genecarp is offline
Old 04-09-2008, 07:30 PM   #3
Trade: masonry
What do you mean moisture? Its inside a home. Where is there going to be moisture coming from on a zero clearance fireplace?
If not something like liquid nails, what about something like full flex?
920-680-3195
Visit our website @
Old 04-09-2008, 07:41 PM   #4
Tscarborough's Avatar
The problem is that construction adhesive sets too slow. The rock will slide, and if it is drystacked will tend to stick fine until you have about 4' high done, and then want to peel off en masse'. Why make it hard on yourself? Thinset is your friend.
Tscarborough is offline
Old 04-09-2008, 07:46 PM   #5
master mason's Avatar
Trade: masonry
SIX STRING, Why don't you use a lightweigt thinset ? Skim coat the cement board first with the flat side of the tile trowel, this will push the thinset in.Then use a 1/4x1/4x1/4 trowel to spread the thinset.Then I always back butter the stone and push it in.Works well for me.And since it's dry stack, you wont have any problem at all.MM
master mason is offline
Old 04-09-2008, 08:08 PM   #6
Trade: masonry
Thanks guys. Thinset was what I meant by full flex. Just a brand we have up here.
I guess that would be the way to go. I appreciate the info!!
920-680-3195
Visit our website @
Old 04-09-2008, 08:32 PM   #7
genecarp's Avatar
[quote=6stringmason;417950]What do you mean moisture? Its inside a home. Where is there going to be moisture coming from on a zero clearance fireplace?
sorry, i read a little fast, moisture is just a prob exterior, thinset to wonderboard inside is the ticket
genecarp is offline
grouting cultured stone. need help pls johnny bravo Masonry 11 03-18-2008 09:03 PM
Stone Archway jp33 Masonry 1 01-30-2008 10:10 PM
Stone Wall Pricing CJKarl Masonry 45 01-09-2008 08:23 PM
Mortar Bedding for Stone on Concrete Question. lukachuki Masonry 10 05-26-2007 10:09 PM
