Garage Footer/slab Question
Old 11-27-2005, 11:58 AM   #1
rico55's Avatar
Trade: Builder
I am designing a house that has a an attached garage. It is a two story house, with a single-story garage. What type of footer should the garage have? Should it be the same size and depth as the rest of the house? Do I need to leave a gap in the stem wall where the garage door is?
rico55 is offline
Old 11-27-2005, 12:45 PM   #2
Commercial construction
mikesewell's Avatar
Trade: Commercial construction
Re: Garage Footer/slab Question
Originally Posted by rico55
...What type of footer should the garage have? Should it be the same size and depth as the rest of the house?...
Talk to a local geotech, or a structural engineer. We don't know what your local soil conditions are.
It's a good idea to have the elevation of the stem wall high enough to keep the framing off of the ground. This usually means that you have to make a cut in the wall for the apron and the overhead door. A cut in the wall is not difficult, nor is it expensive.
I hope that this helps,
Sewell Construction
mikesewell is offline
Old 11-27-2005, 12:51 PM   #3
shopdust's Avatar
Trade: Cabinets millwork spec builder
A lot depend on your local codes (interpetation) I.E. In most areas your footers would be 15" X 18*" in the two story area, 12"X12" in the garage area. These are the dimensions of the footer going into undistrubed earth or compacted fill, not including the 4 inch (nominal) slab. A quick call to your local building authority will tell you what's req'd in your area.
I would pour it as one unit - monolith
*Or the depth will be below the frost line, again that is a local determination.
shopdust is offline
Old 11-27-2005, 01:23 PM   #4
PipeGuy's Avatar
Trade: underground
I am designing a house... What type of footer should the garage have?
Do you have an architect?
PipeGuy is offline
Old 11-27-2005, 01:31 PM   #5
Priced In
JustaFramer's Avatar
Trade: Exiled For Life
Those are some huge footings depth wise. However is all has to do with the soil. Over the years I have seen 6" deep x 12" to 8" deep x 12"-24"
JustaFramer is offline
Old 11-27-2005, 02:50 PM   #6
shopdust's Avatar
Ayyyup!
jumped into many a trench with a square tipped shovle to clean out spill or extend the depth beyond what the inspector thougth was fill. Earthquakes (and the subsequent lawsuits) are big issues in California.
shopdust is offline
Old 11-27-2005, 02:58 PM   #7
Priced In
Ayyyup!
It won't suprise me if WA will go that deep in the future one good quake and we will again radically reengineer.
Old 11-27-2005, 09:52 PM   #8
shopdust's Avatar
Some 'experts' think the Pacific NW is overdue. That little shake in Seattle made folks think.
Some jurisdictions in Calif. are now allowing 2d stories on remodel residences with 12' x 12' footers over 5 years old. Concrete seems to get harder?
I'm aware of the 90% at 28 days mix, wonder when it tops?
shopdust is offline
Old 11-27-2005, 09:59 PM   #9
Tom R's Avatar
I think it's 'years and years', - - might wanna get Justaframer's answer.
http://www.tr-built.com
Tom R is offline
Old 11-27-2005, 10:31 PM   #10
Priced In
I am still learning with concrete. I work for others on this trade. I have done alot of prep for pours. Set up forms run some rebar. I think I am wrong but it's 65,000-90,000 psi in 28 days. but takes still takes a few years to fully cure.
way over shot that one 3,000 at 28 days. High strength considered at 7,000-14,000 psi
Old 11-27-2005, 11:24 PM   #11
Priced In
http://www.cement.org/basics/concretebasics_faqs.asp
Here is a good fact sheet (I think) on concrete.
Old 11-28-2005, 02:33 AM   #12
mikesewell's Avatar
It is.
Portland Cement Association
www.cement.org
American Concrete Institute
www.aci-int.org
National Readymixed Concrete Association
www.nrmca.org
Concrete Reinforcing Steel Institute
www.crsi.org
ACI membership is a good investment. ACI 318 Building Code Requirements for Structural Concrete gives you the information that you need to meet the Code.
Sewell Construction
garage insulation maderuyck HVAC 2 03-18-2007 12:43 PM
Garage service question Edsollen Electrical 15 12-14-2006 07:21 PM
Garage foundation question??/ Sellncars Masonry 7 07-15-2006 07:05 PM
Flat roof over garage leaking under exterior walk out door IHI Roofing 18 05-30-2006 10:28 PM
