Trade: general contractor/carpenter
Garage Door Opening Question
Good afternoon,
My trade is carpentry and remodeling so concrete rough openings are not my baliwick...maybe one of you can advise me on this.... I am building a garage with an 18' door. I understand the finished opening for the door itself is 18' but what is the masonry opening for framing in the opening. This is a concrete footer/foundation. I am planning to have the foundation wall stop 3" from the fin. size opening, so my rough concrete opening would work out to be 18'6"? This allows me double the room needed for framing the sides. Am I oversizing the concrete opening at the door? thanks for the info....Joe. |
Re: Garage Door Opening Question
OR... should I just make it an 18' opening?
Trailer park boy
Maybe a bit, but I don't think it really matters.
You will just have to frame back in to the required opening for the door. Someone with more experience may think differently tho.
"Industry without art is brutality"
solar guy
Trade: solar contracting
I would make my opening 18'3" to allow one jack to run down beside the concrete and allow me to attach my exterior trim.
Mickey
Trade: residential remodeling
I've put in a lot of garage doors and it always seems to work better to have two studs beside the concrete. Gives more room to attach track brackets and electric eye brackets. It's not absolutely necessary to do it this way but personally I like two studs better than one.
solar guy
Re: Garage Door Opening Question |
Actual door width is masonry opening. 2x6 bucks on the backside of the wall for mounting hardware and door stop/trim to seal it inside the opening.
It ain't Rocket Science unless you are building rockets. |
Not sure where witness protection
is keeping Pennyroyal's, but here in frost country, we run the footing all the way across the opening. Either rest the slab on the block or turn the slab down to the footer. Keeps the slab from heaving up in the center of the opening.
Trade: Concrete & masonry
I've done them anywhere from 18'1" to 18' 4 1/2" (for your application.) In my experience, it really depends on the framer's preference, & I make sure to ask them on every job, unless stated on the print. I've found every framer seems to have a different way they want the opening.
Thanks all, I went with 18'6"
Neolithic, there is a continuous footer on the perimeter. Joe |
Eater of sins.
Trade: Designer/Drafter Extrordinaire
What do your plans say? O.K. obviously you are in one of those places that does not require plans for building, but really, without knowing how the opening is designed and the surrounding footings, walls, grade beams(?) are any we can say here is just a lot of palaver and not necessarily what is right for your situation.
I knkow this is not a help but it does increase my post count. (why that is important I don't really know) Andy. |
| Pole Barn Garage | mrmike | Carpentry | 26 | 10-28-2009 08:29 PM |
| garage guru's | Nath | Construction | 17 | 04-18-2009 11:01 PM |
| Excavate garage floor my only option? | EDHC | Excavation & Site Work | 1 | 12-03-2008 05:16 PM |
| Garage foundation question??/ | Sellncars | Masonry | 7 | 07-15-2006 07:05 PM |
| Flat roof over garage leaking under exterior walk out door | IHI | Roofing | 18 | 05-30-2006 10:28 PM |
