Gable End Collapses.
Old 01-29-2013, 03:29 PM   #41
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
Re: Gable End Collapses.
AAC being the light weight block?
www.dominionmasonry.ca
dom-mas is offline
Old 01-29-2013, 03:32 PM   #42
stuart45's Avatar
Trade: Brickwork
Rewards Points: 1,040
It is.
stuart45 is offline
Old 01-29-2013, 03:33 PM   #43
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
Yep. The stuff floats in water which is weird.
www.bcconstructionllc.com
BCConstruction is offline
Old 01-29-2013, 04:29 PM   #44
concretemasonry's Avatar
Trade: Masonry consultant
Rewards Points: 2,920
Depending on the grade, type of AAC, the strength is also different in different directions depending on the orientation when the "loaf of bread" is oriented before slicing. The processes vary wildly and they can produce different densities depending on the market. That is why the use standards are different everywhere and most are non bearing except for 1 and 2 story structures.
Most use a non-conventional mortar (for the U.S.) and much thinner mortar joint.
They can float or the cheaper types will sink, but the product is fascinating in its variable properties.
Dick
concretemasonry is online now
Old 01-29-2013, 04:48 PM   #45
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
I've never seen or heard mention of them except on this site
dom-mas is offline
Old 01-29-2013, 05:59 PM   #46
AAC is generally a European product that has been used for decades. Europeans (like most of the world) look on wood as inferior/temporary construction, so AAC, hollow clay tile, brick and concrete block are preferred. Many of the plants producing AAC are located adjacent to large power plants and can use the waste heat and fly ash along with other local materials (ground silica sand, cement, lime, aluminum powder depending on the process) and produce a very stable lightweight building material on a 24/7 basis, but is essentially a solid block with strength and insulation properties that can be controlled. It can be cut with a hand saw, but it has no cores or way to pick it up or handle it easily.
A few plants, based on European processes, were built, but it was like swimming upstream because of the American preference for lightweight stick construction since we had to find a use for the trees when they were cut down to clear land in the old days.
The AAC plants are very sophisticated and almost identical through out Europe and some of Russia. When I was in Russia at a plant, someone asked me if I wanted to see the grinding ball mill, I said "I know where it is because I was in identical plants in Poland, Czech Republic and Germany". The Finnish/Swedish plants are somewhat different.
It is just a different construction material that has been used successfully in many areas.
Dick
Old 01-29-2013, 07:16 PM   #47
cleveman's Avatar
Trade: custom home building
Rewards Points: 2,624
Is the YTONG or something like that one brand in Germany?
cleveman is offline
Old 01-29-2013, 07:33 PM   #48
fjn's Avatar
Trade: mason
Rewards Points: 9,220
Aac block producers:http://www.toolbase.org/TechInventor...ntDetailID=690
fjn is offline
Old 01-29-2013, 07:55 PM   #49
txgencon's Avatar
Rewards Points: 430
Inner sting.
I used to think a lot of the people I encountered were stupid - then I realized how much I was overestimating them.
txgencon is offline
Old 01-29-2013, 09:11 PM   #50
cleveman -
Ytong is a German company that has been involved in some plants in the U.S. They are heavy on their name recognition, support and good technical support. They even sell saws and the thinset type mortar used and everything is delivered in yellow poly with a big YTONG printed on the packaging. In other words, they sell a building system and not just a product.
Hebel(sp?) is also another German company. I think both companies produce wall panels. I saw some (from a Hebel plant?) in FLA that were used as interior partitions in homes. They were set after the trusses were set and the house was dried in. That shows the light weight of the wall panels that can be finished with joint tape and a skim coat.
Most of the European systems are not branded, but the products are virtually the same since the products can be made/wire cut in different shapes and sizes.
Dick
Old 01-30-2013, 04:03 PM   #51
fjn's Avatar
Trade: mason
Mason builds own home with aac blocks.
http://articles.chicagotribune.com/2...s-minimum-wood
fjn is offline
Old 01-30-2013, 05:06 PM   #52
The problem frequently involved in all masonry construction (brick, block, AAC, etc.) is how the wall works after it is built. That on top of the proverbial question - "Does mortar hold masonry units together or keep them apart?"
Dick
Old 01-30-2013, 06:16 PM   #53
lukachuki's Avatar
Rewards Points: 1,002
Interesting link but no pictures.
I'm a little mean, but I make up for it by bein' real healthy. Earnest T. Bass
lukachuki is offline
Old 01-30-2013, 06:27 PM   #54
Trade: Construction
Dick you may know this. I was on a job in england where they had a machine that pumped a resin type stuff between the bricks as they laid them. bascily replaced the mortar and was meant to be much stronger and faster. never have seen or heard about it since then. it was on a government project for a school.
Old 01-30-2013, 07:23 PM   #55
fjn's Avatar
Trade: mason
Here you go!
http://news.google.com/newspapers?ni...g=6360,8781516
fjn is offline
Old 01-30-2013, 07:29 PM   #56
lukachuki's Avatar
Those aren't color!
Just bustin yo chops.
Thanks Man!
Old 01-30-2013, 07:54 PM   #57
fjn's Avatar
Trade: mason
Those aren't color!
Thanks Man!
Here,use these,
https://www.google.com/search?q=cray...w=1366&bih=613
fjn is offline
lukachuki (01-30-2013)
Old 01-31-2013, 10:59 AM   #58
pappaking's Avatar
Trade: Engineer
Hi All.
I saw this on the news and found your posts on Google.
The canopy carport is made by canopiesuk Ltd.
There is nothing new about these collapses.
If you search Google for COLLAPSED CANOPIES or
COLLAPSED CARPORTS you will find safety warnings sent to the schools
and many images of theses collapsing.
Here are some of the modes of failure.
The GRP cantilever beams fail my snapping.
The steel brackets bends and or snaps.
The wall fixings fail in tension.
The outer and sometimes the inner wall collapse due to the overturning effect.
100 of these canopies in the uk have failed from wind and or snow loading.
pappaking is offline
Old 01-31-2013, 11:07 AM   #59
pappaking's Avatar
Trade: Engineer
Hi All.
Hi all
I saw this on the news and found you posts on Google.
COLLAPSED CARPORTS you will find safety warnings sent the schools
Old 01-31-2013, 11:37 AM   #60
Trade: Construction
why are they allowing them to be used still?
seal gable vents after ridge vent installed? tacoma5050 Roofing 41 06-07-2012 07:32 PM
Over Framing a cross gable roof to a open great room (cathedral) rusticlife Framing 20 09-23-2011 11:46 AM
Gable on the Ground jimAKAblue Framing 19 06-20-2011 07:56 AM
ridge vent / gable vent help enforcer Roofing 53 03-05-2011 12:56 PM
Need new ideas for stucco design on Gable ends?? kdub1777 General Discussion 0 07-13-2010 07:50 PM
