Foundation Waterproofing?
Old 04-11-2007, 08:09 AM   #1
Designing YourImagination
TurnkeyConst's Avatar
Trade: Custom Remodeling
Yes I have a 3 car garage to build well the back of the garage will be backfilled to 3 1/2' high. We will install a foundation drain but does the foundation also need to be waterproofed?
TurnkeyConst is offline
Old 04-11-2007, 08:19 AM   #2
concretemasonry's Avatar
Trade: Masonry consultant
Re: Foundation Waterproofing?
Yes.
This is in addition to the cheap damp proofing usually used it should be waterproofed if you are a goood contractor. It is cheap.
how about the sloping sides?
Dick
concretemasonry is offline
Old 04-11-2007, 10:19 AM   #3
turbomason's Avatar
Trade: Mason
Waterproofing should always be applied on any foundation wall as well as a proper drainage system with proper fill such as washed rock. and its never a bad idea to compact the gravel also. as to avoid settling. Very important in areas which are subject to freezing and thawing...
turbomason is offline
Old 04-11-2007, 11:25 AM   #4
tkle's Avatar
Originally Posted by concretemasonry View Post
Yes.
A lot cheaper than water damage.
tkle is offline
Old 04-11-2007, 03:26 PM   #5
Thanks guys for the input had thought about waterproofing but noticed alot of other contractors are just putting in foundation drains. we will go the whole way and waterproof it just to have double protection against water!!!
By Far the Best Forum Around.
Old 10-17-2007, 11:01 AM   #6
Hosken's Avatar
Trade: custom SFR
I have a similar issue I'm working on. I'm building a concrete dome and the HO wants to berm/backfill (to about 4 feet) the south facing side of the house (in FL) to help cooling. I told him it's probably not worth the water intrusion headaches. Since it's a dome, there are no gutters so the roof water will run right down the sides to teh edge of the foundation...
If he persists, what product should I use to waterproof the wall? It's made of poured cement panels reinforced with wire mesh and fiber. I don't want to use tar and felt, since I've seen that leak too quickly.
Hosken is offline
Old 10-24-2007, 01:06 AM   #7
DREWALAN3's Avatar
Trade: CONCRETE CONTRACTOR
I Agree With Dick.
I Is Good Practice To Do It Right Before You Put The Mud Down. It Will Save You A Lot Of Headaches Money And Sleepless Nights Down The Road.
DREWALAN3 is offline
Foundation repair (New business) Help! crosshair66 Business 10 05-18-2008 09:19 AM
foundation grade problem snuddenstang Masonry 23 08-20-2007 10:07 AM
Demo a foundation under a radiant heat slab without disturbing the slab...? wackman Remodeling 18 04-02-2007 12:38 AM
Venting through a stone foundation MinConst Remodeling 6 12-07-2005 10:34 PM
