#21 |
Re: Foundation Grade Problem
No vents The homeowner might sign it off but my local inspectors wouldn't.
#22 | |
Re: Foundation Grade ProblemQuote:
No 'shot' nails, - - I would imagine (trying to remember) that I placed bolts every 16", alternating one up, one down, - - and above and below each I would have installed tapcons. Install your fasteners horizontally along the top and the center of the ledgers rather than along the bottom so the wood will shrink 'up' from the bottom, more than 'down' from the top. Also install the ledgers a little high to begin with to allow for some shrinkage. As far as the anchor bolts, - - yes - - if I remember correctly, - - they extended into the plane of the plywood, but not above . . . Last edited by Tom R; 08-16-2007 at 06:37 PM. |
#23 | |
It was between the homeowner and the inspection department, - - didn't matter to me either way, - - but you're right, - - they did give him one hell of a hard time, - - but they finally gave in. |
| Foundation repair (New business) Help! | crosshair66 | Business | 10 | 05-18-2008 09:19 AM |
| Demo a foundation under a radiant heat slab without disturbing the slab...? | wackman | Remodeling | 18 | 04-02-2007 12:38 AM |
| Slab on Grade fill options? | James Ellis | Construction | 10 | 10-24-2006 01:55 AM |
| Landscape solution to basement moisture problem | RJC | Construction | 3 | 11-21-2005 01:34 AM |
