Foundation Grade Problem
Old 07-26-2007, 10:27 PM   #1
snuddenstang's Avatar
Trade: landscaping
I am adding a family room addition 18x22, crawlspace, block foundation. The grade around the current foundation has only around 2-3 inches of exposed foundation. The town requires 6 inches of exposed foundation. The addition floor will be the same as the existing floors in the house. Any ideas on how to deal with this issue. I cannot just grade the yard as there are lawn sprinklers all over.
snuddenstang is offline
Old 07-26-2007, 11:31 PM   #2
tkle's Avatar
Re: Foundation Grade Problem
Build your foundation out of 12" block with a course of 6's on top.The 12's supporting the floor and the 6's supporting the wall.
tkle is offline
Old 07-27-2007, 06:54 AM   #3
Trade: landscaping
So then you would essentially have 2 seperate sill paltes. 1 for the floor system and the 6 inch for the wall system?
Old 07-27-2007, 09:01 AM   #4
DRIFTWOOD
Driftwood's Avatar
Trade: GEN CONTR.
Also ,You could install a short retaining wall several ft. off the new work,giving you a walkway around it. They shouldn't be able to address the existing home,it's signed off.
Driftwood is offline
Old 07-27-2007, 06:45 PM   #5
Edsollen's Avatar
Just completed a 2 room addition with the same concept, we used 10 inch block with a row of 6 inch on top. i dropped the siding down to the top of the 10 inch block. Worked fine.
Joel
Edsollen is offline
Old 07-27-2007, 08:20 PM   #6
tkle's Avatar
Tens would work also.Yes you would have two different plates.The 6" block would be the bottom 8 inches of your wall.Your drywall could overlap and bonded with glue or furring strips could be used,leaving room for foam insulation and a way to nail your molding.
An adjacent retaining wall or curb as suggested would also serve your purpose.You could possibly bring it around the existing house so you could restore it's clearance.It's good to have to keep water and termites away.
tkle is offline
Old 07-27-2007, 09:08 PM   #7
Edsollen's Avatar
Used 2x8 floor joist on the 10" block so the floor was up to the bottom of the wall.
Edsollen is offline
Old 07-27-2007, 09:51 PM   #8
tkle's Avatar
Yeah but that would be too easy.
tkle is offline
Old 07-30-2007, 06:13 AM   #9
Trade: landscaping
Is there any way to achieve this using 8" block as that is what is on my plans.
Old 07-30-2007, 06:52 AM   #10
DRIFTWOOD
Driftwood's Avatar
Trade: GEN CONTR.
The floor rim is all the bearing You need! Ever see a ledger bolted to a masonry wall? Keep it simple. Don't forget p.t. lumber at concrete wood contact!
Old 07-30-2007, 06:13 PM   #11
Trade: landscaping
I was just thinking of that. I am uning 8" block. How would you fasten the Rim joist to the block? Would you drill into the block and epoxy lag bolts? I am using PT wood for my sill plates.
Old 07-31-2007, 10:00 PM   #12
tkle's Avatar
A 6" block on top of the 8" would still give you the same bearing as a ledger while still maintaining your 6"outside clearance.Possibly a 4 hi.
tkle is offline
Old 08-01-2007, 05:54 PM   #13
tgeb's Avatar
What I have suggested a few times and has worked out well is to bump the block "out" 4" to give you a brick ledge. You can then proceed with the framing as you typically would, add a few courses of brick around the perimeter. Make sure that you waterproof what will be below grade and you have a good looking solution that will keep your framers happy.
If the job has budget, I always recommend that they run the brick up to the bottom of the windows, then run a row lock along the top.
www.gebcon.com
tgeb is offline
Old 08-01-2007, 11:11 PM   #14
Trade: landscaping
When you say bump the block out 4". Are you still using 8" block?
I am using 2x6 framing also, not 2x4.
Old 08-01-2007, 11:15 PM   #15
Trade: landscaping
Can you just plaster the sheeting on the rim joist over some metal lath?
Old 08-02-2007, 07:51 AM   #16
tkle's Avatar
I'd go with a good coat of latex paint
tkle is offline
Old 08-12-2007, 07:37 PM   #17
Tom R's Avatar
Just saw this post. Here's one I did (right here in Jersey) a few years back with 8" block, - - similar situation with the grading.
If you didn't figure out how you're doing it yet, - - maybe I can 'dig up' the plan
Tom R is offline
Old 08-15-2007, 09:41 PM   #18
Trade: landscaping
Tom,
How did you achieve what you have done there? I can't really see what is going on in the pictures.
Thanks, Mike
Old 08-15-2007, 10:15 PM   #19
Tom R's Avatar
Basically just bolted the rim joists to the walls, - - can't remember for sure, - - but I probably used 1/2" wedge or sleeve anchors (red-heads) and tapcons. The homeowner signed-off on the (lack of) foundation vents, he didn't want them. If he did, - - I'd have had to put them slightly below grade in area-wells. I lined everthing up so there was still a sill plate on top of the block wall, - - and my sub-floor sat right on top of it, - - then the wall framing on top of that. Here's my original drawing, - - hope you can make out the detail . . .
Tom R is offline
Old 08-15-2007, 10:56 PM   #20
Trade: landscaping
Tom, When you bolted the ledger to the wall, did you just use a hilti and shoot nails into the block? How far apart?
Did you sink your anchor bolts into the sill so your subfloor could go right over them?
Foundation repair (New business) Help! crosshair66 Business 10 05-18-2008 09:19 AM
Demo a foundation under a radiant heat slab without disturbing the slab...? wackman Remodeling 18 04-02-2007 12:38 AM
Slab on Grade fill options? James Ellis Construction 10 10-24-2006 01:55 AM
Landscape solution to basement moisture problem RJC Construction 3 11-21-2005 01:34 AM
