Footing High Water Table
Old 02-24-2010, 12:10 PM   #1
excelsior's Avatar
Looking for some advice on pouring footings on top of stone. I have been told that by putting the footings on stone it will help keep the basement dry. My plan is to put the stone at the point where I hit the water table. I'm in up state NY and building a house where the water table is about 6 ft down ( my excavator dug a test pit last month). The local stone quarry is telling me to use a #2 crushed limestone. My question is whether I will be able to tamp this larger stone enough to be used under footings? I was under the impression that the larger stone was better for drainage and it doesn't seem like you can have good pack and drainage at the same time. Never used stone under footing and have always used natural stone around footings not crushed stone. Also any input on whether it will even help with stone under footings?
excelsior is offline
Old 02-24-2010, 08:29 PM   #2
Chief outhouse engineer
dakzaag's Avatar
Trade: mason
Rewards Points: 786
Re: Footing High Water Table
Are you a home owner? I understand in this case you are the home owner, but are you really a GC or just the gc for your own home? There is a section for homeowners to ask questions, if this applies to you then you should go there.
#2 is a good load bearing stone, often the first layer down when building a road or driveway. How are you going to pour the footing on top of water?
Lots of questions, not so many easy answers. Get someone who knows what they are doing to help you. A house should last 60-80 years, it won't kill you to take the extra time and do it right the first time. And the money you save by doing it right the first time you can send to your friends at CT.
D K & Sons
The maintenance schedule for brick
1. Stand back and say "man that looks nice!"
2. Repeat as often as needed.
dakzaag is offline
Old 02-24-2010, 09:07 PM   #3
excelsior's Avatar
DK I am a contractor with most of my work is in fire restoration and additions. This is a project where I am trying to get a dry basement. The plan as I mentioned was to put down stone at the point where I hit the water table(not in the water), after which we would pour the footings. As far doing things right the first time that why I'm bouncing the idea off of guys on this site
Old 02-24-2010, 09:31 PM   #4
katoman's Avatar
Trade: carpenter
Rewards Points: 2,000
We use what is called shot rock. This is stone 3-4" in size. No problem with compaction, but we use a large machine for this, not a hand held unit.
I'm not familiar with your local stone designations, every area seems to use different terms. For a difinitive answer as to what to use in your particular situation, you could consult a soil engineer.
Might be worth the couple hundred bucks. I should note that in our case, it is a soil engineer specifying and signing off on the proper stone product, and the installation of it.
katoman is offline
Old 02-24-2010, 09:59 PM   #5
General Contractor
greg24k's Avatar
Rewards Points: 7,244
Keep your basement floor elevation 1' above the water table and you will have a dry basement. I'm building homes with high water table all the time, doing a house right now, water table is at 54".
greg24k is offline
Old 02-24-2010, 10:19 PM   #6
concretemasonry's Avatar
Trade: Masonry consultant
Rewards Points: 2,890
Drain tile inside or outside (or both) at he bottom of the footing is the cheapest thing you can do to get a dry basement and reduce the lateral pressure on the walls. - Drain to daylight and put in a sump and pump.
Dick
concretemasonry is offline
Old 02-24-2010, 10:54 PM   #7
"Pro"
Ayerzee's Avatar
Trade: Construction Engineering Student
Send a message via AIM to Ayerzee
I don't mean to hijack the thread but this got me thinking. Is it true that backfilling with tile instead of #57's is better because the tiles lock together and don't put any lateral pressure on the foundation walls?
Dan
Ayerzee is offline
Trestle table folding foot? Environments Finish Carpentry 6 08-06-2009 10:20 PM
duomatic olsen leaking water Slyfox HVAC 1 07-27-2009 06:51 PM
Water in Footing Holes.... fakie99 Masonry 11 06-12-2009 04:10 PM
High water table = shorter roof life? Pavola Roofing 4 12-26-2007 07:18 PM
Brick Footer and Water Proofing emtaboy Excavation & Site Work 24 07-24-2006 08:48 PM
