Footing Details
Old 09-23-2008, 01:15 PM   #1
gladiatorxx's Avatar
Trade: Prof Cont
Footing Details
We are pouring a new footing, but have to do so in sections, since this is a repair of walls, so we have to keep to walls up, while we work the other 2. Also we are dropping everything 8". Other than rebar at the end, whats the best way to stop and then join the footing together on the next pour, do you guys use a keyway also?
gladiatorxx is offline
Old 09-23-2008, 06:14 PM   #2
concretemasonry's Avatar
Trade: Masonry consultant
Re: Footing Details
Run some rebar through the joint. In many areas it is nor necessary to reinforce the footing for a basement wall. - Commercial is different.
Dick
concretemasonry is offline
Old 09-23-2008, 07:50 PM   #3
brick4life's Avatar
Trade: masonry
Re: Footing Details
We bulkhead off with plywood drill holes for your rebar to exted through then take a 2x4 and 45deg cut the edges lengthways and nail in to your plywood to form a key to lock footings together.
brick4life is offline
Do I need a footing for this? ruskent Masonry 15 09-04-2008 10:57 PM
Footing Forms for Residential use Clamps/brace for plywood forms plazaman Excavation & Site Work 5 08-21-2008 10:21 PM
footing drain question chrisk Construction 5 09-02-2007 07:08 PM
footing depths WNYcarpenter General Discussion 18 07-14-2007 10:47 PM
Looted New Orleans Architectural Details Cole General Discussion 2 06-05-2006 05:25 PM
