Trade: Electrician
Flooring Issues, Self Leveling? What To Do.
Im currently remodeling an area of my building. Its on a concrete slab, and the rooms not to big, maybe 15''x15'' max. The concrete is old, chipped in a few places, and some of the joints are out of wack. Its not horrible, no serious damage. But its a clean room for some food processing, and we want it to clean up nice Is there a quick fix, we have talked about maybe a self leveling layer over the existing, or maybe epoxy floor coating. maybe a pour over it, but would that work, Demo is not an option here due to the placement of the room, and how it ties into the warehouse. Any ideas, or am i crazy?
Trade: Epoxy Flooring & Concrete Overlays
Re: Flooring Issues, Self Leveling? What To Do.
I don't think epoxy would be the right option for this particular floor, just by what you described. An overlayment would be a good choice. Im not sure about floor levelers, i have never used them. Im sure someone here can help you on that one. I do know if you plan on putting an overlayment or epoxy on top of the floor leveler you are going to want to use a portland based floor leveler rather than a gypsum based one.
Trade: Plumbing & HVAC, I specialize in Hydronic Heating and more specifically in Radiant Floor Heating
Re: Flooring Issues, Self Leveling? What To Do. |
It sounds like you need a S/L underlayment and then an epoxy flooring to me, since it is food service.
It ain't Rocket Science unless you are building rockets. |
Well, since he said its chipped and the joints are out of whack those would areas would probably need corrected first. Epoxy would be expensive as heck to use as an actual floor "leveler".
Now a trowel down marble chip epoxy would be a different story. The floors are usually 1/8" thick when done and you can hide a lot of defects with it. Last edited by JBBS; 08-07-2008 at 11:25 AM. |
I have done a commercial kitchen where we patched all the chips and edges with a sanded gel epoxy, then coated it all with a sanded epoxy finish. Still there, as far as I now 10 years on.
#7 | |
Re: Flooring Issues, Self Leveling? What To Do.Quote:
Trade: Electrician
Ok, thats good info, now what stuff am i using for sanded gel epoxy, and whats the max thickness to go to correct defects? Whats the application process, prep etc. Or somewhere to research it, or just tips in general. thanks guys
Anyway you could post some pics so we know what were looking at?
Trade: Electrician
| leveling floor for nail down planks | ike_in_nc | Flooring | 5 | 08-01-2007 01:53 AM |
| Hardwood Flooring - First Go at It | DecksEtc | Flooring | 56 | 10-05-2006 01:41 PM |
| General flooring issues | Atricaudatus | Flooring | 3 | 05-29-2006 04:10 PM |
| Question about floating wood flooring | zoner11 | Flooring | 10 | 01-17-2006 05:04 PM |
| Re-claimed Vertical grain fir Flooring | Coop | Flooring | 5 | 11-13-2005 08:49 PM |
