Exposed Concrete Foundation Finish Question
Old 11-03-2009, 02:11 PM   #1
3-D Mason's Avatar
Trade: masonry...
Visited a site early last week and the homeowner wants his exposed PIP concrete foundation parged (exterior)to hide some honeycombing and add a bit of texture.
He likes the way the masons finished the project across the street, so I walked over and took a look. The problem is I have no idea what they did. Its a cement based product, applied after the forms had been stripped. At first glance I thought it was EFIS but its applied directly to the concrete approximately 1/8-3/16" thick at the most.
I was just curious as to if anyone here has an alternative to a wire and 2 coat system for this situation.
I will be presenting my proposal tomorrow and will see if the homeowners across the street will allow me to snap a few pictures to post on here.
3-D Mason is offline
Old 11-03-2009, 02:39 PM   #2
genecarp's Avatar
Re: Exposed Concrete Foundation Finish Question
Stucco applied directly to foundation, no wire, no mesh, Go to Franklin Stucco, GMOD
Here------------http://www.franklinstucco.com/
genecarp is offline
The Following User Says Thank You to genecarp For This Useful Post:
3-D Mason (11-03-2009)
Old 11-03-2009, 03:39 PM   #3
Framer53's Avatar
Trade: Framing
Ask at the masons supply house.
I have used morter mix and a latex additive, works very well.
Framer53 is online now
Old 11-03-2009, 04:17 PM   #4
NJ Brickie's Avatar
Trade: Bricklayer
I am not an expert in EIFS but I have seen EIFS applied directly to masonry many times. Why do you not think that it is EIFS because it was directly applied to the concrete?
NJ Brickie is offline
Old 11-03-2009, 04:42 PM   #5
3-D Mason's Avatar
Trade: masonry...
It very well may be EFIS I have absolutely no experience with it and was unaware that it could be applied directly to the glossy finish on the concrete.
The only difference I can tell is that the texture on the foundation doesn't have the swirls that are typically associated with the EFIS jobs Ive looked at in my area. Could just be a difference in technique. thanks
Old 11-03-2009, 05:05 PM   #6
Tscarborough's Avatar
That is not a good application for EIFS, nor is there any advantage to using it there. EIFS is not ground contact to start, and there is no particular advantage to insulating a PIP foundation (above grade).
Regular mortar and bonding agent, integral color if required.
Tscarborough is online now
Old 11-03-2009, 05:39 PM   #7
concretemasonry's Avatar
Trade: Masonry consultant
Compatible materials are always the first choice unless you change your mind.
Dick
concretemasonry is offline
Old 11-03-2009, 08:27 PM   #8
4th generation's Avatar
Trade: Masonry
Ive found that if the concrete is shiny, old & dirty or has been painted then its best to sandblast then parge-coat and sand finish with a piece of styrofoam block after it has gotten thumb print hard. For a 2 coat system (which is what I use on the above grade portion of my block foundations) use a scarifier on the first coat let dry then apply the top coat and add a sand finish with the styrofoam block. Using a sandblaster may sound intimidating but its way faster than wiring an old concrete foundation and it gets a more intimate contact with the concrete than wire lathe .
4th gen
4th generation is offline
Old 11-03-2009, 09:17 PM   #9
CR2's Avatar
Trade: Stone,brick,block,concrete,decorative concrete..
A polymer modified sprayable overlay(hopper gun), fine, medium, coarse, plain, knock down, stenciled, roller textured, any color, choices are endless, your call.
Regards!
CR2 is offline
Old 11-03-2009, 10:26 PM   #10
jgray152's Avatar
Trade: Faux Rock Creations
Could go a little crazy, use better faded colors and more blends of colors on each "rock" and do something like this. Lots of time but it works and is probably the most durable. Grinder Carved.
jgray152 is offline
Old 11-03-2009, 10:41 PM   #11
Trade: Masonry
Nicely done
4th gen
Old 11-03-2009, 11:29 PM   #12
Rockmonster's Avatar
Trade: Masonry
Silpro concrete finish in grey.....half C-21 and half water....grind the foundation, trowel on CLEAN concrete, not damp though....sponge for texture....Maybe 1/8 inch, and looks great.....that's our method....
Rockmonster is online now
Old 11-06-2009, 02:22 PM   #13
3-D Mason's Avatar
Trade: masonry...
thanks for all the great options
glue down on concrete - question JohnHomeMatters Flooring 41 10-30-2009 08:17 PM
Exposed Pebble Concrete Patio Help photogoat Concrete & Paving 2 03-12-2009 08:04 PM
Exposed aggregate with Stamped concrete border bigbadjim Concrete & Paving 9 02-21-2009 07:25 PM
exposed deck w/EPDM on concrete (no pitch) kellry27 Decks & Fencing 0 09-22-2008 09:03 PM
pwf foundation fastener question surferal Carpentry 7 04-15-2008 02:47 PM
