Trade: masonry
Dryvit Over Block Problem
If anyone has info: HO has a block exterior cellar way with dryvit over it.It was all new construction 6 years ago.Now water is coming through the block and blistering up the dryvit.It will all be stripped down to the block.What needs to be applied to the block before new dryvit to not have the same problem happen later?
Trade: Masonry consultant
Re: Dryvit Over Block Problem
Is this a real Dryvit exterior(insulation and Dryvit stucco) system? If it is, apparently water got behind the Dryvit somewhere up above, drained down and is showing up on the portion backed up by the block.
Find the source of the water before guaranteeing any patching. If the above grade is wood frame, the owner could have a big problem, because the Dryvit system is not allowed over wood frame construction. Most of the sources are around windows. The water gets is and behind the insulation.
Dick Engineer, designer and consultant recently active domestically and internationally on construction and design in about 35 countries. |
#3 | |
Trade: masonry
Re: Dryvit Over Block ProblemQuote:
| Cinder Block walls, block filler and a leak...question | SeanATL | Painting & Finish Work | 9 | 03-09-2009 04:33 PM |
| Does fireplace opening in block wall opening need support? | Square-One | Masonry | 6 | 11-22-2008 02:31 AM |
| Moisture Problem | Milhaus | Commercial Construction | 6 | 12-26-2007 02:47 PM |
| Just boguth a new short block for race car:) | IHI | Off Topic (Non Trade) | 4 | 09-21-2006 09:25 PM |
| Does fireplace opening in block wall opening need support? | Square-One | Construction | 1 | 02-28-2006 01:59 AM |
