Drilling Pavers
Has anyone ever drilled 1.5" to 2" holes thru these type of pavers?
http://woodsshop.com/DESIGNS/Spa/9.htm They're very hard, and my mason will need to drill holes thru a few. My thinking is that a regular rotary hammer drill bit would probably break them, so I'm wondering if that would in fact work, or maybe is there a carbide hole saw type of bit that would do a better job? This is the application. I'm setting posts for a patio cover onto the pavers. I've already set my footings, 1/2" lower then the surrounding base material, with a 1/2" allthread sticking out at the post location. I'll attach my standoff post base to the allthread. He'll lay some very dry grout onto my footings, level with his base material, then set his pavers onto the grout, and he'll need to drill those holes so that one paver can drop down over the 1/2" rod. http://woodsshop.com/PROJECTS/Hari/base.htm
http://woodsshop.com/ |
Re: Drilling Pavers
Try slowing down the hammer and running water on the bit.
Re: Drilling Pavers
I have had the best result starting
with a smaller hole and stepping up the bit sizes. But I've never gotten away with too many without breaking some.
Re: Drilling Pavers
Just split and nibble the pavers. It isn't worth the effort to try and drill them.
It ain't Rocket Science unless you are building rockets. |
Trade: building for 30 years. new homes , additions
Re: Drilling Pavers
I use a hi speed grinder with a hole saw for granit and tile it should go thru like butter.
Re: Drilling Pavers
I don't understand Wellbuilt, you don't hook the hole saw to the grinder do you?
Seems to me like a hole saw would cut a 1.5" hole alot easier then a regular hammer drill bit would? Would you use a carbide or diamond tipped hole saw for this?
http://woodsshop.com/ Last edited by Joe Wood; 09-06-2008 at 05:14 PM. |
Handle It!
Re: Drilling Pavers
A grit hole saw!
Trade: Masonry consultant
Re: Drilling Pavers
A 1 1/2" to 2" hole in a 4" wide paver that is probably 2 3/8" thick. If you are careful and handle it carefully, you can get it in place. Get the pavers cored somewhere. - they are not too heavy to move.
That is a real strange detail with some of the pavers sitting in grout on a concrete footing and the rest sitting directly on a compacted soil base. - Any side load on the post?
Dick Engineer, designer and consultant recently active domestically and internationally on construction and design in about 35 countries. |
Re: Drilling Pavers
My problem was, if I set the posts onto CB66 post bases, the paver guys would have to cut the pavers around each post, leaving the post bottoms in a hole where they'd possibly stay wet. The way I've decided to go, all the posts will land on top of uncut pavers and look alot better as well as staying high and dry.
Not sure what you mean by side load on the posts, but here's a pic of the design, there'll be 6 posts altogether, all at slightly different elevations because of the slope. Don't think the paver guys will want to stop what they're doing to go get each of the 6 pavers cored, they'll need to core them as they're laying.
Re: Drilling Pavers
Technically, the post anchors should be set to grade and dry-pack grouted before the paver guys get there, then they cut around them.
Re: Drilling Pavers
TS has got it right.
Re: Drilling Pavers |
Re: Drilling Pavers
Ya, that might be a good way to do it, but that's not what I'm asking about as my footings and allthread are already in.
Re: Drilling Pavers
It's not only a " good way", it's the correct way to carry the load.
Re: Drilling Pavers
Right. Put a nut on the all-thread at the correct height. Place the post anchor, then another nut. Get non-shrink non-metallic grout and drypack (which means damp pack) under the anchor.
#16 | |
Re: Drilling PaversQuote:
My experience is mostly with iron types where it won't be exposed. Watching this it occurs to me I can't name a structural non-metallic.
Re: Drilling Pavers
Sono-grout 10K or several of the Sika grouts are nationally available.
As an aside, the purpose of the metal shavings is to rust and swell an amount equal to the shrinkage of the cementious portion of the grout. The non-metallic grouts do the same thing using manganese or other non-ferrous minerals and are much more stable and predictable.
#18 | |
![]() I've used, literally, tons of ferrous grout for red-iron base plates and couldn't come up with one brand name for a non-ferrous.
#19 |
Re: Drilling Pavers
OK thanks fellas, appreciate the input, but I really only want to know what the proper drill bit would be to make 1.5" holes thru these pavers.
#20 | |
had to do it, I started small and stepped up to 1". (Cast aluminum faux Paris street lamps with 4 bolt bases.) Couple of thoughts... Drilling on sand seemed to provide a cushion and reduce the breakage. Maybe less chance of breakage if, after roto-hammmering a pilot, you just went rotary only and step up more gradually. You've only got 6 to do, right? This advice is probably worth exactly what you paid for it.
| Pavers Over Concrete - My Cousin's Method | Tommy C | Masonry | 67 | 10-29-2009 10:31 PM |
| cement wash or concrete rub a thin layer over brick pavers | brownstone89 | Masonry | 14 | 08-25-2008 07:14 PM |
| Drilling slab over dentists office... | lazerguy | Plumbing | 16 | 10-05-2007 01:31 PM |
| Sub Base for pavers | mcgyverdc | Landscaping | 20 | 01-14-2007 02:48 PM |
| Ants overtaking my pavers | maj | Landscaping | 10 | 06-30-2006 12:08 PM |
