Does This Small Pool Wall Need Rebar?
Old 02-19-2018, 01:01 PM   #1
sockaplayr1's Avatar
Trade: General Contracting
Rewards Points: 2
So I'm in the process of remodeling my backyard. One of the things I wanted to do was build a wall similar to this one on my pool.
I had someone come out and build the small wall (it's 28" high from where the pool already ended (where the the white ends in the pictures below and it's 18 feet long) and will be putting stacked stone on it (real stone, so it's heavy). The stacked stone will go from just above the water level where the red tile ends in the pictures below and cover the whole front and sides of the wall.
My question is, should this small wall have rebar in it? I'm not sure the sub-contractor who built it put any reinforcement into the wall and it is a very long wall. Should he have drilled into the part of the pool already there and put rebar into it? (or is that dangerous/could cause leaks in the pool and crack the side) Or is rebar in just the new sections fine? Or does it not need rebar at all? The wall is obviously not very tall, but my concern is the stacked stone is super heavy and it's all on the front part of the wall, could it topple over without rebar? Should I tear it down and start all over again?
Or am I fine because it's so short? Any help would be greatly appreciated. I need the expertise of you guys who are masonry pros.
sockaplayr1 is offline
Old 02-19-2018, 03:33 PM   #2
tgeb's Avatar
Rewards Points: 946
Re: Does This Small Pool Wall Need Rebar?
Well, find out if he did or did not install reinforcing steel drilled into the pool edge.
One way to find out would be to get a few guys out there to push on it. If it falls into the pool, it is not tied in.
www.gebcon.com
tgeb is online now
The Following 4 Users Say Thank You to tgeb For This Useful Post:
Bull Trout (02-19-2018), Fouthgeneration (02-24-2018), heavy_d (02-19-2018), Mordekyle (02-19-2018)
Old 02-19-2018, 03:36 PM   #3
tgeb's Avatar
Rewards Points: 946
Another thing, what is the stone going to set on for support the tile edge?
www.gebcon.com
tgeb is online now
Old 02-19-2018, 03:59 PM   #4
Bull Trout's Avatar
Rewards Points: 988
the building inspector was cool with no rebar?
Bull Trout is offline
Old 02-19-2018, 04:23 PM   #5
Rewards Points: 2
He definitely did not, hence my question. Im wondering if i need to start over abd build a new wall.
It's a stone veneer so it'd just stack on top of itself. First row would have a board under it to support it until the adhesive mortar dryes. It is pretty heavy though.
There was no inspector since the wall is under 3 ft tall and its not a retaining wall per se.
So should it have had rebar/support of some sort when it was built? Should i take the whole thing down and build from scratch and add some anchors on top of the existing pool block (the white area)?
Old 02-19-2018, 05:47 PM   #6
Wormdrive Operator
heavy_d's Avatar
Trade: Contractor
Rewards Points: 6,498
Well if you are a general contractor like you say in your profile, what would you do if you were building this for a customer?
Sent from my SM-G930W8 using Tapatalk
heavy_d is offline
Old 02-19-2018, 05:53 PM   #7
DaVinciRemodel's Avatar
Trade: Design/Build Remodeler
Rewards Points: 770
A mod should be by to help soon. The post usually starts with “Thank you for posting to Contractor Talk…”
I love what I do and I'm very good at it!
Da Vinci on the web or Da Vinci On Facebook
DaVinciRemodel is offline
The Following 2 Users Say Thank You to DaVinciRemodel For This Useful Post:
Bull Trout (02-19-2018), Jay hole (02-19-2018)
Old 02-19-2018, 05:54 PM   #8
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 2,053
Thanks for posting on ContractorTalk.com. The Moderators of this forum would prefer that you post Do It Yourself related topics on our sister site www.DIYChatroom.com
ContractorTalk.com is designed for professional contractors to discuss issues and topics related to the construction and remodeling industries. Many of our professional contractors are also members at DIYChatroom.com and are looking forward to assist you with your needs.
Please take a moment to post your question at www.DIYChatroom.com If you're not already a member of DIYChatroom.com you can sign up for a free account by going to http://www.DIYChatroom.com/register.php/
We apologize for any inconvenience that this may have caused. This thread has been closed.
Tinstaafl is offline
The Following 3 Users Say Thank You to Tinstaafl For This Useful Post:
Bull Trout (02-19-2018), fjn (02-19-2018), Fouthgeneration (02-24-2018)
Florida Pool Contractor Qualifier Wanted! kelkayne Help Wanted or Looking For Work 3 09-18-2016 05:58 PM
Double wall or spray foam jdorpaudi Insulation 10 06-05-2015 08:37 PM
Shear Wall Plywood Nailing & Structural Issues sbebuilders Framing 12 02-04-2013 10:35 PM
Tie in the small interior wall groups. Why? Willin Framing 23 11-01-2012 07:58 PM
Shoring Exterior Load Bearing Wall for Beam insertion larch General Discussion 4 01-27-2012 06:47 PM
