Do You Guys Use These? - Masonry - Contractor Talk
Old 12-07-2017, 11:03 PM   #1
dbrons's Avatar
Trade: Masonry
Rewards Points: 608
I never saw them till I moved to the west coast.
dbrons is offline
Old 12-07-2017, 11:08 PM   #2
brickhook's Avatar
Trade: masonry
Rewards Points: 7,570
Re: Do You Guys Use These?
No, I hadnt seen that before...does it work good?
brickhook is offline
Old 12-07-2017, 11:33 PM   #3
dbrons's Avatar
Trade: Masonry
Rewards Points: 608
Yes, they work great. You can use where other line tools won't work like a split face block. You can even use as a twig.
dbrons is offline
Old 12-07-2017, 11:36 PM   #4
General Contractor
greg24k's Avatar
Rewards Points: 7,516
Most still use line blocks around here.
greg24k is offline
Old 12-07-2017, 11:40 PM   #5
brickhook's Avatar
Trade: masonry
we use corner poles and line blocks, we use line-dogs if we are laying up leads
Old 12-07-2017, 11:51 PM   #6
Renaissance Man
superseal's Avatar
Rewards Points: 5,586
Intense rebar schedule in earthquake country...I feel for you guys.
supersealconstruction.com
superseal is online now
Old 12-08-2017, 10:27 AM   #7
fjn's Avatar
Trade: mason
Rewards Points: 9,560
John,are line -dogs the same thing we call dog bones ?
Every region has their own lingo.
https://www.homedepot.com/p/Bon-Tool...Fc-9swoduM8GDw
fjn is online now
The Following 2 Users Say Thank You to fjn For This Useful Post:
brickhook (12-08-2017), Inner10 (12-08-2017)
Old 12-08-2017, 11:30 AM   #8
fjn's Avatar
Trade: mason
I bought two pairs of these gadgets at the start of the season. They work nicely on short leads,they come from our buddy Stuart's backyard.
https://bricky.com/building-tools/builders-line-anchor/
fjn is online now
Old 12-08-2017, 01:23 PM   #9
AustinDB's Avatar
Rewards Points: 840
Those are some cool tools
AustinDB is offline
Old 12-08-2017, 06:02 PM   #10
Smarter than the brick...
Kniggit's Avatar
Trade: Masonry
Rewards Points: 561
Chicken legs
Kniggit is offline
The Following 2 Users Say Thank You to Kniggit For This Useful Post:
brickhook (12-08-2017), fjn (12-08-2017)
Old 12-08-2017, 06:03 PM   #11
brickhook's Avatar
Trade: masonry
...probably so, the correct name for them is line stretchers...we ve used them for years. and they work really well
The Following User Says Thank You to brickhook For This Useful Post:
fjn (12-08-2017)
Old 12-08-2017, 06:11 PM   #12
fjn's Avatar
Trade: mason
I like them also. The fixed size or the sliding type. The ones with the various holes,not so much.
fjn is online now
Old 12-08-2017, 06:25 PM   #13
brickhook's Avatar
Trade: masonry
I had some sliders that I really liked on split-faced block. But the ones that I use have holes drilled for 4" 6" 8" 10" and 12 " block.
fjn (12-08-2017)
Old 12-08-2017, 06:30 PM   #14
brickhook's Avatar
Trade: masonry
When I built my shop, I was reaching for the DOG to raise my line and the smart azz on the the other end was trying to pull the line in to.
My DOG slipped off and hit me right in the chest, it knocked the wind out of me.
The next day I had a bruise the exact outline of the DOG...
The Following 2 Users Say Thank You to brickhook For This Useful Post:
fjn (12-08-2017), Fouthgeneration (12-08-2017)
Old 12-08-2017, 06:33 PM   #15
fjn's Avatar
Trade: mason
While we're at it,these come in handy also. They work on brick or 4" block.
fjn is online now
Old 12-08-2017, 07:06 PM   #16
fjn's Avatar
Trade: mason
oops ! Forgot to post them.
https://www.bontool.com/line-line-ho...e-clips-11-793
fjn is online now
Old 12-08-2017, 09:15 PM   #17
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 6,835
One of our local masons, just past, made 'frogs' out of 10 gauge dovetail masonry anchors, bent in a U-shape sized to fit either the 4-8" CMUs and the larger U-shape welded to the smaller, held on to 10-12" blocks, and some large hole bricks.
My Dad made frogs that look like a rebar 'Hickey' bender, a flat piece of 1/8" x 1.25-50" bar stock about 3-4" long, with 5/16ths-3/8ths x 1" tall pins spaced differently on either side, welded to it to grip brick with core holes.
One trick to keep the leads with the line work is always place the bitter enc of the line between the taut line and the lead so every time the offset is the same.
I fail to see how the corner gizmo would work on the lower courses of the lead with out molesting the mortar somewhat... And who every pulled the line tight on a single brick....unless it was laid yesterday.
I will copy the spring clamp usage for "jack" lines though.
I have and sometimes use the tool FJN posted, more often on short walls working alone though, some rougher and rounded brick wont work with them reliably.
Fouthgeneration is offline
Old 12-08-2017, 09:31 PM   #18
JBM's Avatar
Trade: Masonry
Rewards Points: 5,422
Do you have a link , i have a split face job on the horizon
JBM is offline
Old 12-09-2017, 03:49 AM   #19
stuart45's Avatar
Trade: Brickwork
Rewards Points: 1,066
https://www.jagclamp.com/
stuart45 is online now
The Following 2 Users Say Thank You to stuart45 For This Useful Post:
dbrons (12-09-2017), JBM (12-09-2017)
Old 12-09-2017, 10:44 AM   #20
fjn's Avatar
Trade: mason
[QUOTE=Fouthgeneration;
I fail to see how the corner gizmo would work on the lower courses of the lead with out molesting the mortar somewhat... And who every pulled the line tight on a single[/QUOTE]
Very valid point ! The gizmo only works for the spot and lay method.
Also,the conventional wooden line blocks the supply companies have been giving away have such a incredibly deep groove,it changes the bricking point from the lead. What I have done to make a permanent fix is mix up a small amount of Durham's water putty and fill in all but a line depth of the groove. Makes placing $100 bills in there unnecessary.
fjn is online now
Fouthgeneration (12-14-2017)
what do you guys use to get leads? sam2424 Online Leads Services 46 07-03-2018 09:44 AM
Can You Guys repairsplus Help Wanted or Looking For Work 2 11-01-2012 01:13 PM
Hey guys Moejo New Member Introductions 2 09-27-2012 10:24 PM
Trying to recycle and help guys out done4fun Roofing 5 06-15-2009 09:09 AM
