Direct Vent Fireplace Into Brick Wood Burning Chimney?
Old 05-24-2006, 11:20 AM   #1
rach0990's Avatar
Trade: contractor
Hi and thank you for your help.
I am trying to install a ” napoleon “ direct vent fireplace into an existing wood burning chimney. The problem is that the insert is bigger than the actual opening, it does not fit in. I was thinking to remove few bricks from the side and the above opening inside wall.
Is it safe? Does it cause any damage to the outside walls and the general chimney structure?
rach0990 is offline
Old 05-24-2006, 11:47 AM   #2
jvcstone's Avatar
Trade: Masonry / architectural stone carving
Re: Direct Vent Fireplace Into Brick Wood Burning Chimney?
Are you a mason.?? I suspect not. This is something you should have a knowlegable professional look at. Sometimes the brick facing is just a veneer, and as such can be altered. However, sometimes the brick facing is an integral part of the fireplace "workings" , and if this is the case, removing brick or other alterations could lead to a dangerous situation. A mason could determine what is what, and advise you how to proceed, but only by looking.
Why not select an insert that will fit in your existing firebox??
JVC
John VanCamp
www.jvcstoneworks.com
jvcstone is offline
Old 05-24-2006, 09:55 PM   #3
stacker's Avatar
Trade: masonry
i was thinking the same thing.and not tring to be a smart a%$,it could have been a gimme,garage sale buy or anything else that sounded to go to be true.i cant see any fireplace shop selling an insert without knowing the demensions of the opening.
stacker is offline
Old 05-25-2006, 07:20 AM   #4
tkle's Avatar
Can the insert be cut down?
tkle is offline
brick work on exterior of fireplace qwert General Discussion 12 07-24-2007 06:19 AM
Wood Between Siding and Brick sgrprince Masonry 9 07-07-2007 02:30 PM
Gas Fireplace - To Vent or Not Hardibuilt General Discussion 8 05-08-2007 10:58 AM
Questions About a No Good Chimney Bruce Masonry 11 01-02-2007 12:46 AM
Brick Veneer Chimney w/ Factory Insert rhomfeld Carpentry 6 09-15-2006 09:23 PM
