General Contracting
Trade: Real Estate Broker, Property Manager
Demo Masonry Fireplace
I have a Masonry Fireplace I need to demo. No problem, but I need to leave the Masonry Chimney intact.
Here is my questions: Can I expect the masonry chimney to run to the floor (cement floor) or does it terminate on top of the firebox? |
Re: Demo Masonry Fireplace
It's a unit, not divisible. What are you trying to do?
General Contracting
We need to remove the fireplace, but they want the chimney to remain in case they want to add a wood stove and I guess for the shear amout of work involved in removing a chimney 2 1/2 stories high on the inside of a house.
The flue sits on top of the firebox. the firebox supports it kind of like an arch.
Maybe just strip the face, and block up the opening? There would need to be some kind of clean-out though.
General Contracting
I was afraid of that, but I had someone tell me they build the chimney from the floor up and the firebox sits in front of it. Made some sense since the firebox isnt 3' deep, but the exterior of the fireplace is.
I guess to demo the chimney we would need to start from the top down. Whcih we can get to the first 6' but then I will have 8' behind the walls of which I would not want to open up. Any clue as to if they woud have attached any part of the framing to this structure OR if I removed the top 6' and then worked in the basement, could I let 8' of the chimney come down into the basement? ![]() Sounds as scarey as I am writing it, but just wondering. |
Probably scarier than it sounds even
![]() I don't think it'll "slide "down gently! This is why so many are abandoned in place. How old is the house? Does the flue have a clay liner/tile?
General Contracting
Yes, Clay liner in the flu
Wait, Basement?
How big is the structure in the basement?
General contractor?I'm scared.
Work from the top down.It's only 8' behind the wall.Take the debris out the top,leave the wall.Watch out for dead birds. Last edited by tkle; 11-11-2007 at 08:21 AM. |
Is it a two story house, or one story with a basement?
Trade: Bricklayer / contractor
Please video the 8' your gonna let slide down into the basement. In fact get a few cameras set up. we need some split screens especially one with the look on the HO face.
Oh and then when your getting sued get a screen writer in to take notes. Thet sort of comedy value doesnt come along often.
General Contracting
I bet you'd want a piece of the action if I win the $10k on Americas Funniest Videos then too! I'd rather ask a stupid question than to do something stupid.
Honestly, I was under the impression the the chimney was straight to the floor. I had masons tell me this! However, I do not know as I never built or supervised a full masonry chimney and firebox. I do know that we use to put footing under where they would be when they were speced for for an oil burner flu and given the dimensions of the exterior of the fireplace sides and the interior of the firebox, I am ending up with a huge area behind the fire box. So it made sense that this massive structure was supported by the floor and not the fire box. So if you have built or demo'ed a Full Masonry Fire Place, I'd like to hear it from you. And if my history has anything to show for my work, when I attack this project, it will be done right with no injuries and no structural damage and the homeowner will end up with exactly what they want. |
General Contracting
Re: Demo Masonry Fireplace |
Trade: masonry
its just like neo said,the clay flue liners sit on the firebox.if you remove the firebox,then nothing is supporting 15 plus feet of chimney flue
![]() the outside of the chimney will go all the way to the footer.but that is like clothes to you and i,take it away and the chimney is naked.
life is short,do your masonry naked!! http://ok.local.yahoo.biz/knabemasonry/index.html |
General Contracting
Now that makes sense. I'll see if we can come up with a plan "B' for him or demo the entire thing from top down
#16 | |
It's all about the Avatar
Trade: I have no face!
Re: Demo Masonry FireplaceQuote:
The first thing that fails on a normal fireplace is the flue. That is why most fireplace dealers run chimney liners. All that work around the the flue is bound to knock a joint loose. |
#17 | |
Why do the demo and leave a dead space? If you don't want the space, abandon it in place. I'm confused.
#18 |
Breaking the chimney from the top down and dropping the brick down the flu will allow the proccess to migrate through the house with out even opening walls, unless the chase is real small.
#19 | |
General Contracting
It was on a modular home and they installed the chase, all 32' of it, without waiting for the fireplace and chimney. Only thing we could do was to get in there and build it from the fire box up. I could not get anyone willing to do it so in I went. Climbed up the chimney with a nail gun and some 2x4's and they slid the zero clearance fire place in and fastened it. Then they dropped the chimney sections down to me. I attached them and climbed up. Did this all the way up. But the hole was too small for me to get out so I had to duck down as they cut it bigger to let me out. I have pics of that one somewhere. FYI: I have a fear of getting stuck in tight spots especially since I am 6'4" , 215lb. Now I don't know that I could do a 24 x 24 space, but maybe I could find someone smaller that is willing. Ideally it is what he would prefer. |
#20 | |
| Does fireplace opening in block wall opening need support? | Square-One | Masonry | 6 | 11-22-2008 02:31 AM |
| fireplace framing | sonic_loser | Framing | 6 | 11-05-2007 12:35 AM |
| Fireplace Insert Raised off the Slab | Hambone | Masonry | 14 | 04-22-2007 09:54 PM |
| Fireplace Insert Raised off the Slab | Hambone | Construction | 7 | 04-20-2007 11:57 PM |
| Does fireplace opening in block wall opening need support? | Square-One | Construction | 1 | 02-28-2006 01:59 AM |
