Trade: framer
Deep Hole / No Pockets
I had a someone dig a basement for me. Instead of digging it about 4 feet deep. He decides to dig it 9 feet in the back and about 8 feet on sides with the front open. I then had the basement wall built 15 courses high. The questions is this , I was told I will have to fill the blocks and rebar to make sure that the ground pressure won't cave in the walls. These are 8" blocks. The soil is clay and shale .
Also was told to backfil with gravel appox. 40 yards gravel. Then backfill Labor to backfill $900.00 Plus $ 800.00 for gravel |
young gc
Trade: general contractor
Re: Deep Hole / No Pockets
yes, you will have to rebar and fill with concrete. Here if you have more than 6' of unbalanced backfill you have to pour and rebar. One question I have is why did you only want your basement dug out 4'. When I do a basement house I typically go between 12-15 block depending on what floor sytem I am using. If using trusses I will go with 12-13 block. If using tgis I will go with 15 block, allowing me to run my hvac underneath them.
www.cssconstructionllc.com |
Trade: framer
The lot is about 15 ft up from the road and it is atop of a montain that is 2684 feet up and overlooks a valley. I wanted just 4 feet dug into the hill , I should tell you the baement has a drive up gargage.
The cabin has two floors. Cssonstruct the property is about 60 miles from Knoxville near Spring City Last edited by gman; 08-20-2006 at 08:21 PM. |
young gc
gotcha. It will also be hard to look at your prices as compared to other people. Getting materials and machinery to your jobsite sounds a little more difficult than bringing it to the local subdivision.
| Customers with endless deep pockets... | Mike Finley | Business | 36 | 06-24-2007 10:13 AM |
| punch a hole in concrete /w #2 | POOLMANinCT | Masonry | 7 | 06-23-2007 12:50 AM |
| Back panel hole | england030 | Carpentry | 2 | 05-18-2007 10:05 PM |
| three hole receps on a ungrounded system? | Steve Unkie | Electrical | 2 | 12-09-2006 11:44 AM |
| Found a hole | clcrider7 | Landscaping | 2 | 05-20-2006 01:15 AM |
