Trade: General Remodels
Decorative Concrete Finish
How do you pour a patio with the pea gravel look?
Trade: GC/Remodeling
Re: Decorative Concrete Finish
with pea gravel
-Steve "The most beautiful thing we can experience is the mysterious. It is the source of all true art and science." ~ Albert Einstein |
Trade: woodworking
exposed aggregate finish? If that is what you mean the place you order your cement through will double the amount of aggregate in the mix. Finish it like a normal pad and when it is set up to a point you rinse it with a garden hose, it rinses the slurry off the top and leaves the rocks showing.
To do an exposed aggregate finish properly - 1)order a specific exposed aggregate mix. It will have a specific type and gradation of aggregate, water reducers, and probably some retarder. Specifics will change based on location. 2)Place and bowl float finish only. 3) Spray a surface retardant on the surface and cover with black plastic, 4) Let sit for 6-12 hrs based on temp. 5)remove plastic and power wash.
Most failure of exposed aggregate finished conrete is caused by people just washing the surface without a surface retardant. You lower the water/cement ratio and you don't have a good bond on the bottom of the aggregate. The surface retarder ectches in the surface 3/16" to 3/8" (depending on the type you buy) and allows a good bond on the bottom before you wash it off. |
| Staining concrete | ryan.s | Masonry | 12 | 03-05-2009 03:54 PM |
| Decorative Concrete Biz? | 2006Silverado | Concrete & Paving | 29 | 11-29-2007 08:29 AM |
| Sticky finish...Boy could I use some advice | Uuber_Framer | Flooring | 11 | 10-26-2007 04:41 PM |
| concrete driveway finish standards | henryr | Masonry | 10 | 04-29-2006 06:53 PM |
