#21 |
Trade: Masonry
Re: Dangerous Chimney Dilemna
Isn't California a separate country?
![]() Sorry, had to throw that in. I have relatives in CA.
#22 |
THIS is one crazy post BOSS
#24 |
Pictures?
"The problem with internet quotes is, you never know if they are authentic." -Abraham Lincoln- Less with the jaw more with the paw! |
#25 |
Trade: chimney inspector, consultant, and contractor
Unsafe chimneys must be torn down and replaced. There is no suitable way to partially repair this. Remember, you are bringing fire into a home----one with a documented unstable footing. When they ever sell this house, this will be an impediment or hidden defect.
You could replace the masonry chimney with a factory built woodburner supported on a cantilever by the framing. However, you would still have an inefficient woodburner that does contribute some to particulate emissions. Better to install an EPA certified hybrig half fireplace half woodstove. Many models now on the market that are tested and listed as a system and should meet any air quality board requirements. FYI, that flue extender is a gimmick and not a recognized method because it does not extend the 'chimney'. It is a modified 'cap'. HTH, Hearthman
Keep the fire in the fireplace! Certified Fireplace Inspector & Master Hearth Professional UL Standards Technical Panel 103 BoD HPBA & International Assn. Fireplace and Chimney Inspectors |
#26 |
Owner
Trade: CA Remodeler
1) French Perimeter Foundation Drain to redirect the streams flowing through the basement. This will reduce future house movement.
2) Take down the chimney very very carefully to the firebox and put up a stainless flue. 3) Post some pictures for all of you who were kind enough to give me good advice. Thanks all |
#27 | |
Trade: stonemason
Re: Dangerous Chimney DilemnaQuote:
#28 |
Trade: Pipe Fitter
Simple. Offer to install some C-4 with a Mercury Switch so the thing will fall straight down when the earthquake hits. We do this all the time.
| Tags |
chimney, earthquake, retrofit, strap, strapping ![]() |
| Chimney problem | Jack3185 | Masonry | 2 | 04-20-2009 09:28 PM |
| Chimney leaks, permeates water | beavhut | General Discussion | 10 | 09-02-2008 05:40 PM |
| Chimney woes | Rich Turley | Masonry | 4 | 09-18-2007 08:09 PM |
| Questions About a No Good Chimney | Bruce | Masonry | 11 | 01-02-2007 12:46 AM |
| Chimney & Creosote question | BreyerConstruct | General Discussion | 33 | 12-14-2006 08:02 PM |
