Cultured Stone On Sheetrock
Old 04-21-2008, 09:44 PM   #1
deffed's Avatar
Trade: 22 yrs ceramic tile, stone & wood flooring
can you install cultured stone on sheetrock with thinset on a fireplace with a metal firebox, or do you have to use the felt and lathe mudcoat
deffed is offline
Old 04-21-2008, 09:54 PM   #2
Mike Finley's Avatar
Trade: Bathroom Remodeling
Rewards Points: 2,000
Re: Cultured Stone On Sheetrock
You can install it on sheet rock like most people did with silicone or liquid nails. You might be the first person in history who went to the trouble of applying that stuff with thinset.
Mike Finley is offline
Old 04-21-2008, 10:51 PM   #3
Tscarborough's Avatar
Rewards Points: 1,406
I beg to differ. For a few of the styles, namely Cultured Stone Pro-fit, you can get away with using a bond-coat type primer on sheetrock. Cultured Brick can be applied with thinset over the primer as well.
Using a liquid nails, silicone, or mastic to attach adhered veneer to sheetrock will be an exercise in frustration, and void every manufacturer's warranty, such as they are.
Tscarborough is offline
Old 04-22-2008, 12:33 AM   #4
DOH! I read cultured stone somehow as cultured marble.
Please disregard
Old 04-22-2008, 07:49 PM   #5
raskolnikov's Avatar
Trade: masonry
Rewards Points: 258
Everytime I see "cultured stone" I can only think of the "sea monkeys" you got at the local fairs and carnivals. Not a dig, just a memory lapse!
D.
raskolnikov is offline
Old 04-26-2008, 08:57 AM   #6
deffed's Avatar
I have installed ceramic tile and stone ( marble travertine ect) for years on fireplaces over sheetrock using thinset I thought you could do the same with the lightweight stone
deffed is offline
Old 04-26-2008, 07:52 PM   #7
stacker's Avatar
Trade: masonry
Rewards Points: 542
you are looking at two entirely different products,weights and thicknesses.
i know alot of ppl out here are using thinset to lay adhered veener stone.
but i am one who will never use it.i will always use my mason cement and wire lath(where needed.)
stacker is offline
Old 04-27-2008, 09:08 AM   #8
tkle's Avatar
I never use straight thinset. It doesn't have enough body.
I won't install phony stone directly over drywall, most manufacturers don't suggest it, however I've torn it down when attached to drywall. Half the board comes down with it. It sticks pretty darn good.
tkle is offline
Old 04-28-2008, 01:18 PM   #9
Thinset over concrete board, Type N over lath or CMU.
Old 04-29-2008, 06:18 PM   #10
Jakecanteraman's Avatar
Trade: Cantera Stone
I agree with Tscarbarough we have been using concrete bonder and thinset for cantera. That stuff will take down the drywall if you try to take it off.
canterasdelsurcom.
Jake
Jakecanteraman is offline
Old 04-29-2008, 07:06 PM   #11
tkle's Avatar
canterasdelsurcom.
Jake
Cantera has a smooth back.Profit has a fairly smooth back. Most phony stone doesn't have a smooth back. Normal thinset doesn't have enough body to account for this. Filler is needed. Mixing thinset at different ratios with type N mortar will achieve these results. Using excess thinset to compensate not only creates more mess it also takes longer to adhere. It stays wet longer and will slide or pull away if not held for an extra moment. It also won't create the desired suction that thinset mixed with mortar will.
tkle is offline
Old 04-29-2008, 08:21 PM   #12
I have never seen a faux rock with a smooth back, but the natural thin cut stone I use is smooth and I have no problems with either. If you feel it needs more body, mix it drier. The bond strength of Type N mortar is barely sufficent for application to backer board (especially with smooth back veneer), and the added thickness is often an issue.
Cultured Stone rockbrain Masonry 46 06-04-2015 10:25 AM
grouting cultured stone. need help pls johnny bravo Masonry 11 03-18-2008 08:03 PM
base of wall w/ cultured stone TAO Masonry 5 03-18-2008 03:03 PM
Cultured Stone Fireplace andrew07 Masonry 2 10-30-2007 07:27 PM
How to remove cement from cultured stone? ruskent Masonry 9 01-31-2006 03:07 PM
