Cultured Stone
Old 10-30-2008, 08:35 AM   #1
trades01's Avatar
Trade: mason
Cultured Stone
i have recently took on a job to finish a contractors job to finish laying some cultured stone ledge stone to be exact. he was fired from the job and i can see why. but my problm is that he has got mortar all over the face of the rock. now when i lay stone i wash the stonel with a luke warm water at the end of the day so no mortar is left on the rock. what can i clean the rock with after mortar has set up for a coupe of weeks? this is in a house for a firplace.
trades01 is offline
Old 10-30-2008, 09:01 AM   #2
Tscarborough's Avatar
Re: Cultured Stone
There is no good way, really. You might have to remove those stones and replace them.
Tscarborough is online now
Old 10-30-2008, 09:10 PM   #3
stacker's Avatar
Trade: masonry
Re: Cultured Stone
depending on how much is on the stone,you might could try a small wire brush.and even then would use it very lightly.DO NOT,use any type of acid product on it.spic and span might remove some,works wonders.good luck
stacker is offline
Old 10-30-2008, 11:38 PM   #4
RZB's Avatar
Trade: masonry
Re: Cultured Stone
I Know my supplier sells a specific manufactured stone cleaner, for products like cultured stone. It's milder and won't bleach out the coloring in the stone.
RZB is offline
Old 10-31-2008, 04:57 PM   #5
CJKarl's Avatar
Trade: Masonry
Re: Cultured Stone
Don't use a wire brush, you could "burn" it and leave streaks of grey from the metal.
Stiff plastic brush.
There's Always A Market For Quality
http://www.kaufmannmasonry.com/
CJKarl is offline
Old 10-31-2008, 05:36 PM   #6
stacker's Avatar
Trade: masonry
Re: Cultured Stone
thats why i say lightly.i have taken mortar from stone with a wire brush with no effect to the stone.
stacker is offline
Old 10-31-2008, 06:02 PM   #7
Re: Cultured Stone
I use a wire brush on it to remove mortar, but not old mortar. For the little spots, I just chip it off with my knife, or touch it with my rotozip, but for large amounts, those won't work.
Old 10-31-2008, 06:21 PM   #8
genecarp's Avatar
Re: Cultured Stone
Whatever you decide to try, take a piece or two of the cultured stone, put mortar on the face just like the other guy did, then let it dry, and begin to try to remove it with different methods. after you find what works, then go at it on the installed fireplace..G
genecarp is offline
Old 11-02-2008, 11:01 AM   #9
scotbox's Avatar
Trade: builder
Re: Cultured Stone
when installing cultured stone over hardi backer, what is the best method ?
scotbox is offline
Old 11-02-2008, 11:45 AM   #10
Blockade's Avatar
Trade: worker
Re: Cultured Stone
Follow the manufactures recommendations; each company has a specific recommendation, there in nothing generic about a custom made product. Both for taking off old mortar and for installing the product.
Typically you start at the top and work your way down for stone that needs to be pointed/grouted after it has been installed such as river stone and the reverse for ledge or stacked stone. This could be the reason why the stone has motar all over it in the first part of this post.
Blockade is offline
Cultured Stone rockbrain Masonry 38 08-12-2009 10:54 AM
cultured stone ? wellbuilthome Masonry 7 08-19-2008 12:33 PM
grouting cultured stone. need help pls johnny bravo Masonry 11 03-18-2008 09:03 PM
Cultured Stone Fireplace andrew07 Masonry 2 10-30-2007 08:27 PM
How to remove cement from cultured stone? ruskent Masonry 9 01-31-2006 04:07 PM
