Trade: Drywaller
Cultured Stone 45 Degree Corners
How do you guys recommend joining cultured stone on a 45 degree angle? This is on a fireplace application that has 45 degree angles back to the intersecting wall. Cut to a butt joint?
KemoSabe
Re: Cultured Stone 45 Degree Corners
Pick some of the longer stones, pick a point and miter them back at opposing 22.5 degree angles. Butt them tight with some adhesive. Quality cuts should be fairly convincing that they are one piece.
It depends upon the stone. Which one is it.
It ain't Rocket Science unless you are building rockets. |
Trade: GC/Remodeling
Gee T, he done told us it's the 'cultured' one
-Steve "The most beautiful thing we can experience is the mysterious. It is the source of all true art and science." ~ Albert Einstein |
Trade: Drywaller
This is what a contractor is proposing. To me this looks bad. Your thoughts?
That is about as good as you are going to get on a 45 with faux stone.
Trade: Stone,brick,block,concrete,decorative concrete..
I agree, nothing wrong with this job, as good as it gets, but if you think it looks bad, what's your idea to make it look better, maybe we learn something today, I just don't buy the mitter and glue method, there's no way to get rid of the vertical joint, maybe I'm wrong.
Regards! |
Pretty hard to get away from. You can cut just one side to fit the other alternating your cuts. That will break it up slightly. With some stone it works. With others it looks like crap.
Trade: Drywaller
What if alternating mitre cuts were made on each row to reduce the appearance of a straight line. Or is this going to make the appearance look more artificial and is create a ton of work. Would any of you make cuts or just butt the "stones" up to each other leaving a gap? Does $800 seem reasonable for labor on a job like this? My fireplace is just like the one in the picture, not quite as tall (about 70 sq. ft). Overall they want $1,750 including a floor hearth.
Thanks for everyone's input. |
#10 | |
Trade: masonry
Re: Cultured Stone 45 Degree CornersQuote:
I did a fireplace like that a while back. It was dry stacked and turned out pretty nice. I cut each 45 on the saw and ran a straight line up the corners. If you do it right you wont see the cuts and it will look good.
Kamps Masonry & Concrete Countertop Design Green Bay, WI 920-680-3195 Visit our website @ http://www.concretecountertopsdesign.com/ |
I have wasted a lot of faux stone trying to determine a way to do decent 45s. As it stands, one of the first questions I ask is, "are there any 45 degree corners", and if the answer is yes, then I push them to adhered real stone, as it can be worked a LITTLE bit better to eliminate the joint line. I still charge a lot more to mess with it, though, enough that no one has taken me up on doing it.
KemoSabe
Sounds fair for this area, are they doing all prep? Wire and scratch? Wire and no scratch?
Trade: Drywaller
They quoted to do the complete job, I assumed they would do the scratch coat.
Does it look like any miter cuts were made in the posted picture? |
KemoSabe
Looks like all factory edges to me, any cuts will show the base color and not the applied stone simulation process. Try the double 22.5 degree method if you can get a couple loose pieces from the supplier. I would try it on a bridge type tilesaw.
old school
Trade: stone masonry
Tuff to make it look real but I've had my best results alternating butt joints. The type of stone matters a lot.
old school
Re: Cultured Stone 45 Degree Corners |
Trade: stone mason
Overlap stone past corner of angle the thickness of stone that will be on other side of angle interlocking just as you would a inset coner as you go up if you are going to use a stockstone. Keep this overlap the same distance all the way up the wall. when you get finished you will have a straight 45 degree corner straight up the wall full of stone that will also make your price worth it.
#18 |
You will also have a big ass gap at every joint.
| The Following User Says Thank You to Tscarborough For This Useful Post: | dakzaag (02-20-2009) |
#19 |
KemoSabe
Try the double 22.5 cuts on a bridge tilesaw. The cut will be tighter and cleaner than any other option. The stone will be the same width and color on both sides because it is the same stone. It won't be invisible but it will look better than any option I have seen so far. It will be time consuming, but thats what seperates perfection from production.
I know I'm not a stonemason,but if you check my profile, I've been around the block, and have seen some creative stuff. Last edited by loneframer; 02-20-2009 at 11:23 PM. |
#20 |
Trade: stone mason
He may have a big ass gap at every joint , he has already asked if 800 is reasonable labor for this job.
| price psf for cultured stone installation | EPD | Masonry | 32 | 02-20-2009 11:43 PM |
| Cultured Stone over Existing Brick Fireplace | fakie99 | Masonry | 7 | 12-01-2008 06:10 PM |
| Coldest weather for cultured stone on exterior? | kdub1777 | Masonry | 5 | 11-05-2008 08:28 PM |
| cultured stone | trades01 | Masonry | 9 | 11-02-2008 11:45 AM |
| cultured stone ? | wellbuilthome | Masonry | 7 | 08-19-2008 12:33 PM |
