Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Masonry
Old 09-07-2007, 11:03 PM   #1
6stringmason's Avatar
Trade: masonry
cultured over cement board
Im doing a column outside for my wife's cousin and her husband. They have the column already built. 2x2x3 and have it covered in cement board(masonite).
Do you think I should wrap the corners with metal lathe? Or will expansion not be a problem with this stuff?
Kamps Masonry & Concrete Countertop Design Green Bay, WI
920-680-3195
Visit our website @
http://www.concretecountertopsdesign.com/
6stringmason is offline   Reply With Quote
Old 09-08-2007, 03:49 PM   #2
Not a problem.Hope they have the rougher side of the board exposed.
I use extra glue with the board.I've never had a problem with it,but I don't trust it.
tkle is offline   Reply With Quote
Old 09-08-2007, 08:51 PM   #3
Trade: mason contractor
Send a message via AIM to laybrick Send a message via Yahoo to laybrick
what would it take to throw a piece of mesh up to avoid any problems ?
laybrick is offline   Reply With Quote
Old 09-08-2007, 08:53 PM   #4
or doubt you may have
Old 09-08-2007, 09:54 PM   #5
...or paper and mesh to start with.
Old 09-08-2007, 11:34 PM   #6
stacker's Avatar
Trade: masonry
i would play it safe and wrap the corners with lath.15-20-30 mins to do it and you wont have to worry.
stacker is offline   Reply With Quote
Old 09-09-2007, 07:58 AM   #7
Trade: Ex-Stucco contractor
All outside and inside corners should be wrapped with lath. And where freeze and thaw cycles happen often a moisture barrier would not be a bad idea.
If it was your house wouldn't you want it done right?
stuccoman is offline   Reply With Quote
Transitioning drywall with cement board Lone Wrencher Drywall 19 03-02-2008 07:05 AM
fiber cement board and plank labor costs ubercontractor Windows, Siding and Doors 11 10-05-2007 08:30 PM
fiber cement board siding wayne3434 Construction 20 05-08-2007 07:02 PM
How to remove cement from cultured stone? ruskent Masonry 9 01-31-2006 04:07 PM
