Trade: masonry
Cracks In Brown Coat
im stuccoing a house.i have stuccoed before.i have a problem,maybe.i am putting my scratch coat 1/4 inch.letting it completly dry,then appling 1/4 brown coat.to ensure a level coat for my finish,i am floating out the brown coat with a rubber float and water,not much water just enough to float it.my problem is that i am getting cracks in the brown coat.
i am using 1/2 sack mason cement,1/2 sack portland cement,and 22 shovels of sand.i have expansions at all doors and windows,above and below.anyone have any ideas?i have thought about using a handful of fibers,but not sure if the will show in the finish coat(it will be a floated sand finish). thanks guys
life is short,do your masonry naked!! http://ok.local.yahoo.biz/knabemasonry/index.html |
Re: Cracks In Brown Coat
Certainly use the fiber for base and scratch coats. Add your fiber to your mix water along with the color and bonding additive; the current crop of fiber do not make hairy finishes. For base and scratch coat, you should not be floating it out at all. Put it on as dry as possible, then let it set to dry-crumbly and use a screed to knock it more-or-less flat. The only layer that has to be nice is the finish coat.
I just finished stuccoing the back side of my house, and it has a LOT of fiber in all three coats: http://72.41.69.75/backwall8.jpg If you are doing a sand finish, however, I would not use fiber in the finish coat. Edit-The most common formula around here is 1 Masonry, 1/2 portland, and three parts sand. Last edited by Tscarborough; 07-02-2006 at 06:12 PM. |
Construction Estimator
Trade: Estimator
Yor bromn coat might be drying too fast? I know several stucco guys who keep it wet for hours after application.
A buck a foot is not an estimate! It's a crap shoot! |
Trade: masonry
that is one thing i was thinking(keeping it wet).after i have floated it down,i have sprayed it down a couple times,but not much more than that.luckily,what i have b/c is on the back of the house,so maybe i can keep it from cracking from here on out.temps here have been running in the high 90's,so i am going to try to keep it wet,along with adding fibers to the mix.
tscar,great looking work.
| 1 coat vs. 3 coat stucco finishing | janrickey | General Discussion | 12 | 07-17-2011 11:22 AM |
| Stucco Finish coat seperating from base coat? | mwcuff | Masonry | 9 | 08-16-2008 08:42 PM |
| 2 coats or one coat | saucedo80 | Painting & Finish Work | 38 | 03-02-2007 08:23 PM |
| Cracks in sink | ChuckEA | Plumbing | 5 | 06-27-2006 09:57 AM |
| Second Coat or not | cowtown | Painting & Finish Work | 16 | 05-24-2006 06:05 PM |
