Crack Walls
Old 05-06-2006, 08:55 PM   #1
tbird2's Avatar
Trade: masonry
Crack Walls
what would make a wall crack in just weeks they r 10 inch block
tbird2 is offline
Old 05-06-2006, 09:12 PM   #2
tkle's Avatar
Re: Crack Walls
No control joints is usually the cause,or they're improperly spaced.Possibly no expansion joint where it meets an adjoining slab.Improper compaction under footing or improper footing.Weak concrete mix.Earthquakes,car wrecks or sometimes they just crack no matter what you do.
tkle is offline
Old 05-06-2006, 09:47 PM   #3
Tscarborough's Avatar
Re: Crack Walls
Provided that the slab is OK, it is almost certainly the control joint layout.
Does the crack follow the mortar joint?
Is the crack in the middle of a wall or at a corner?
Does the crack point towards an outside corner?
Is the crack over a door or window?
Tscarborough is offline
Old 05-06-2006, 10:46 PM   #4
jvcstone's Avatar
Trade: Masonry / architectural stone carving
Re: Crack Walls
foundation failure due to expansive clay soil shows up as a crack that gets wider the higher up the wall it goes. Can follow the head joints, or even break the unit.
JVC
John VanCamp
www.jvcstoneworks.com
jvcstone is offline
Smooth Finish Heavy Textured Walls riccog Drywall 5 03-10-2009 11:57 AM
Block Walls DaHammer Masonry 29 03-06-2009 07:11 PM
Ceiling crack navco1390 Painting & Finish Work 4 01-12-2007 07:34 AM
Bridging for above grade Concrete Walls ETHICS05 Construction 1 11-21-2005 12:43 PM
drywall over interior plaster/ brick walls n8sr Drywall 10 11-10-2005 10:18 PM
