Courtyard Wall
Newbie here but I could use some assistance. No one else could seem to give me a good answer as to the proper way to do the job. Even though I'm not a contractor I would appreciate any advice.
I have a courtyard in my house (its basically C shaped) with 3 sides being the house itself. There is a cement pad poured already for a patio (in North Carolina). I want to have a cement block wall built across the end (approx 15 feet long) with a gate in the middle to basically enclose the courtyard as a privacy wall. It will be freestanding and nonload bearing (no retaining wall). I plan it to be about 5 or 6 feet tall. One plan was to drill into the existing patio, insert the rebar, lay the blocks, and run the rebar horizontally as well. I've also been told that because it's not load bearing I do not need the rebar. I couldn't find the codes for non load bearing cmu wall but I figured I might just go that way to be safe. Thanks for your time. |
Re: Courtyard Wall
The rebar is not for strength in compression, it is for lateral stability. It is best to dowl it in for a freestanding wall, and to grout the cells as required by local code.
It ain't Rocket Science unless you are building rockets. |
Moderator
Re: Courtyard Wall
Are you in one of the contracting trades? I see you have listed your trade in your profile as carpenter. Is that accurate?
#4 | |
...jammin
Trade: Rock Disciple
Re: Courtyard Wall
Thanks for posting on ContractorTalk.com. The Moderators of this forum would prefer if you post Do It Yourself related topics on our sister site www.DIYChatroom.com
ContractorTalk.com is designed for professional contractor's to discuss issues and topics related to the construction and remodeling industries. Many of our professional contractors are also members at DIYChatroom.com and are looking forward to assist you with your needs. Please take a moment to post your question at www.DIYChatroom.com If your not already a member of DIYChatroom.com you can sign up for a free account by going to http://www.DIYChatroom.com/register.php/ We apologize for any inconvenience that this may have caused. This thread has been closed.
Signature Quote Quote:
| Load bearing wall or not??? | BMAN | Remodeling | 26 | 07-28-2008 07:16 PM |
| removing a none load bearing wall?? | samiam | Framing | 7 | 09-12-2007 08:33 AM |
| Backyard office, retaining, and privacy wall | Team Scream | Masonry | 8 | 08-02-2007 11:27 PM |
| moving centennial wall | stacker | Masonry | 4 | 10-20-2006 12:12 AM |
| Low (12" or so) brick garden wall questions | bindersbee | Masonry | 8 | 04-27-2006 08:31 PM |
