Copper On Cement
Old 04-12-2007, 11:39 AM   #1
Capt2's Avatar
Trade: Home Improvement & Repair Contractor
Copper On Cement
I have a water main coming through a poured concrete foundation. THe copper pipe main is encased in a black plastic sleeve. When it rains water comes in through this sleeve.
Can I fill the end of the sleeve with hydraulic water stop cement? I'm hearing conflicting info on whether the cement will hurt the copper pipe inside.
Feedback appreciated. Thanks
Capt2 is offline
Old 04-12-2007, 03:47 PM   #2
concretemasonry's Avatar
Trade: Masonry consultant
Re: Copper On Cement
Hydraulic cement is great when it comes to fixing leaks is concrete.
Your leak in the area between the copper and plastic.
Prep and clean the void completely using water and alcohol. If the gap is large use a bakker rod. Caulk with the best caulk that you can find that will adhere to both the copper and the type of plastic you have for the sleeve.
Dick
concretemasonry is online now
Old 04-12-2007, 09:31 PM   #3
Tscarborough's Avatar
NP1 sealant will work fine, but you will have to prime the metal (for the application above). Edit-it is 733 primer.
Tscarborough is offline
Old 04-12-2007, 10:46 PM   #4
Capt2's Avatar
I used marine grade epoxy putty. I'll see the result next time it rains.
Capt2 is offline
Old 04-12-2007, 10:55 PM   #5
Which one? Some will not create a watertight bond to copper, some will.
Old 04-13-2007, 10:13 PM   #6
Capt2's Avatar
It's Locktite 5 min epoxy. It comes in a cylinder that you break a peice off of and knead it together to mix the 2 parts.
Capt2 is offline
Old 04-13-2007, 10:18 PM   #7
Teetorbilt's Avatar
3M 5200 slow cure. This stuff sticks to anything including you. Mineral Spirits is cleanup unless it cures.
Albert Einstein
Teetorbilt is offline
Old 04-13-2007, 11:05 PM   #8
5200 is as close as humans will come to being God: On the 8th day, God said, "glue it together", and 5200 appeared on the face of the Earth.
Old 04-13-2007, 11:14 PM   #9
Teetorbilt's Avatar
Then He created EPOXIES!
Albert Einstein
Old 04-17-2007, 09:09 PM   #10
Capt2's Avatar
OK so we had heavy rain in NJ and I had used the marine epoxy putty before it started. Basically it held temporarily then started to leak. Just out of curiosity I applied this rubbery gutter sealant that can be applied when wet and bingo, it worked no more leak.
Now if I can just get the other little foundation leaks stopped.
What is the trick to using hydraulic cement??? Can it be applied while the leak is active? I did this and the leak wiggled its way to the edge of the cement.
Capt2 is offline
Old 04-17-2007, 10:28 PM   #11
It can be used (hydraulic cement) only under pressure when you are applying it to the positive side of the pressure.
drywall mud over cement? mudgirl Construction 7 07-20-2007 08:27 PM
Aluminum to copper lug Mike Finley Electrical 21 06-03-2007 12:31 AM
Cement Contact with Copper Pipe Capt2 Plumbing 11 04-17-2007 09:05 PM
Painting new gal. gutters copper DeanV Painting & Finish Work 0 06-22-2006 09:39 PM
Copper vents -vs- plastic/aluminum shopman Roofing 2 03-01-2006 08:51 AM
