Pigs In Pearls!
Trade: home improvements
Conversion For Sq. Ft To Yards Of Concrete
how do you figure your yardage for concrete in an area...
Moderator
Re: Conversion For Sq. Ft To Yards Of Concrete
Area = length x width
Volume = length x width x height (or depth of concrete) To convert cubic feet to cubic yards, divide by 27. One yard = 3 feet 3'x3'x3' = 27 cubic feet =1 cubic yard. Now, having said all that, if this is the first time you're ordering concrete, you might want to get someone with some experience in to help and double check your numbers. You don't work concrete, it works you. Plus, it never forgets... Sorta like a wife.
| The Following User Says Thank You to Double-A For This Useful Post: | navychap (03-23-2009) |
SSSSSh!
Come closer, it's a secret!![]() (Fourth grade math. Keep it under your hat!)
AAAAh!
Snoopy is a blabber mouth!
#5 | |
Pigs In Pearls!
Re: Conversion For Sq. Ft To Yards Of ConcreteQuote:
ive ordered and poured myself before, but its been a while. ive got a gargae addition and ive got the exreience to pour the job myself, i just cant remember so....an area 25 long ft x 30 wide ft x 6 inches deep is 16.6 yards of crete? that seems like a bit much |
Trade: General Contractor, Remodeler
25x30=750 sq'
750/2=375 cu' ('caus its 6" deep div by 2) 375/27=13.88 yds call it 14 1/2 'caus I like extra How'd you get 16.6? |
Trade: Masonry consultant
25' x 30' x 6" (1/2 foot) is 375 cubic feet.
divided by 27 is 13.88888 cubic yards, so order about 15 yards since you grades may not be exact. - Mkae sure you have sidewalk or something else poured so you have a place to put the excess. They usually do not like to take concrete back.
Dick Engineer, designer and consultant recently active domestically and internationally on construction and design in about 35 countries. |
#8 | |
Pigs In Pearls!
i followed this formula Area = length 30 x width 25 =750 Volume = length 30 x width 25 x height .6 =450 / 27 = 16.6 Last edited by shazamyman; 02-06-2008 at 06:17 PM. |
Moderator
Trade: Renovations
Height is 0.5 not 0.6
I'm a Mac
Trade: ICF Construction
Now...who knows how many meters are needed...
Chris |
Pigs In Pearls!
Re: Conversion For Sq. Ft To Yards Of Concreteirealized that earlier, so what would it be if it were four incehs? i have to ask you to excuse me, i have a ninth grade education, but ive got 15 years hands on experience, and 2 years independent contractors experience, ive only done 2 pours on my own and they were small porches... |
Pigs In Pearls!
Re: Conversion For Sq. Ft To Yards Of Concrete |
My ninth grader is doing calculus (that I can't do), but the answer is to divide the little number by the big number, i.e. 4 divided by 12 = .33
It ain't Rocket Science unless you are building rockets. |
For all practical purposes:
1"=.08 2"=.17 3"=.25 4"=.33 5"=.42 6"=.5 7"=.58 8"=.67 9"=.75 10"=.83 11"=.92 12"=1
Neo, did you do that all by yourself? Or did you ask T's 9th grader for a formula? Just razzin'.
Revievl's right, 6" is half a foot (a foot is 12", so half that is, well .5). Easy mistake to make. Got a friend who uses a slide rule kinda thingie her concrete guy gave her... put in length x width x depth and you get the right order off the thing, but I like doing it the "hard" way. For a 4" slab do length x width x (neo table). Divide by 27 than add some, round up, or add more if you're not sure of the grading. My concrete provider will take it back if I order too much, but they charge me for it 'cause it's junk if it's not used. |
#18 | |
In a galaxy far far away..... I was a field engineer, i.e. building layout and site work. Dimensions and grades are all in feet, 10ths, and 100ths. Stuff is engraved in the lizard brain. Handy when doing math with measurements to the 8th!
#19 |
Sure 'nuff
#20 |
There are calculators online like this one: http://www.concretenetwork.com/concr...calculator.htm
Makes things easy to the exact decimal. Footings also. Now, when I am roughing out an estimate, we figure 80 square feet of concrete to the cubic yard if it is a 4 inch slab....60 sq/ft for 6 inch slabs.
| Framing into concrete ceiling | user17661 | Framing | 43 | 11-06-2011 09:46 PM |
| Fiber Optics in concrete countertops | 6stringmason | Concrete & Paving | 17 | 03-16-2011 05:49 PM |
| Staining concrete | ryan.s | Masonry | 12 | 03-05-2009 03:54 PM |
| Concrete home | denick | Concrete & Paving | 5 | 03-06-2007 04:32 PM |
