Concrete Sweating Profusely?
Old 12-15-2011, 10:09 PM   #1
Python49's Avatar
Trade: General
Rewards Points: 75
Sigh, another problem... I noticed that my concrete floors have had occasional days where they sweat like crazy. Literally to the point where I walked into one of them and thought someone had just mopped the whole house. When I walked through with just socks on my feet felt very wet. We used 6mil visqueen in the foundation and the foundations are built with a slope away from the house. Anyone know of some possible remedies for this?
Python49 is offline
Old 12-15-2011, 10:12 PM   #2
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
Re: Concrete Sweating Profusely?
Sell
ohiohomedoctor is offline
Old 12-15-2011, 10:12 PM   #3
Or try a roll on vapor barrier.
Old 12-15-2011, 10:14 PM   #4
Working
Cole82's Avatar
Rewards Points: 2,276
Send a message via AIM to Cole82
Originally Posted by ohiohomedoctor View Post
Sell
Matt I'm not pointing fingers.
To the OP try a dehumidifier.
Cole
The boss of awesome
Cole82 is offline
Old 12-15-2011, 10:15 PM   #5
Cole
I dont it...
Old 12-15-2011, 10:54 PM   #6
Fire up the BBQ
griz's Avatar
Rewards Points: 468
How long have the floors been down?
griz is offline
Old 12-16-2011, 06:27 AM   #7
Sar-Con's Avatar
Trade: Civil Construction, Excavation, Concrete + Forming
Rewards Points: 504
Have you seen this before?
http://www.youtube.com/watch?v=oz0__...ture=endscreen
Sar-Con is offline
Old 12-16-2011, 08:14 AM   #8
Designer/Contractor
Rio's Avatar
Rewards Points: 1,296
From the 'occasional days' line it seems as if there are some days where there isn't a problem and other days where there is. If that's the case I'd start out by making a log and keeping track of the conditions when the heavy sweating is occurring, putting in data such as if it's raining, if sprinklers are going, the humidity, if the windows are closed, and anything else that might have an influence on the slab. This should give you a better idea of what might be causing the problem and once that's determined it's more likely to be able to be successfully corrected
Rio is offline
Old 12-16-2011, 09:38 AM   #9
Thom
thom's Avatar
Rewards Points: 4,748
the water can come from two places, above and below. If it's from above the fix is easy and it's easy to determine what the problem is. From above would be condensation on the cool slab resulting from moisture in the room air being above the dew point of the slab.
Get a hygrometer (humidity tester) and hang it on the wall in the house. These are cheap, you can find them on-line. Find yourself a chart that shows humidity levels at temperature. For example, 70% humidity at 70F air temp will condense on the floor (or walls) when they are 60F.
Assuming your humidity levels are to high, find the source and fix it, or get a dehumidifier. Oftentimes people disconnect the dryer vent in order to "Save" the warm humid air. That will result in condensation as will failing to vent the bathroom after a shower.
thom is offline
Old 12-16-2011, 12:24 PM   #10
stuart45's Avatar
Trade: Brickwork
Rewards Points: 1,010
A method used by some is to tape down a piece of polythene tight to the floor and see whether the moisture is under or on top of it.
stuart45 is offline
The Following User Says Thank You to stuart45 For This Useful Post:
fjn (12-18-2011)
Old 12-17-2011, 10:18 PM   #11
Tubby's Avatar
Trade: Masonry
Wtf...lolololololololol
Tubby is offline
Old 12-18-2011, 01:16 PM   #12
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
Now there's the best start I've heard of yet.
dom-mas is offline
Old 12-18-2011, 01:36 PM   #13
Box Builder
Morning Wood's Avatar
Rewards Points: 8,788
Did you put a vapor barrier under the slab. You say you used 6mil visquen on the foundation. What exactly does that mean?
Morning Wood is online now
Old 12-20-2011, 04:23 AM   #14
hairballxavier's Avatar
Trade: Concrete
Do those work?
hairballxavier is offline
Old 12-20-2011, 04:41 AM   #15
Trade: Concrete
Hate to tell you this, but I think your concrete guy might not be installing the vapor barrier under the floor properly.
The remedy... rip it out.
Old 12-20-2011, 10:02 AM   #16
lukachuki's Avatar
Rewards Points: 1,002
wait wait wait....as has been pointed out this water is very likely condensation. I just got off of a pool deck on which water would condense every night and I couldn't actually get it dried out to work on it till about 2:00 in the afternoon. I'm just saying that this is a strong possibility and is very common.
I'm a little mean, but I make up for it by bein' real healthy. Earnest T. Bass
lukachuki is offline
I need a fence post mounted on a concrete pad. JT Wood Decks & Fencing 23 10-06-2011 11:42 PM
driveway concrete aydin_eng Concrete & Paving 4 03-10-2010 09:36 PM
Tire line in concrete after finishing. aydin_eng Flooring 34 03-09-2010 09:03 PM
structural concrete... mdshunk Masonry 3 03-05-2009 02:42 PM
Concrete stain problem Forry Concrete & Paving 6 09-02-2008 08:10 PM
