Concrete Slab Surface
Old 09-08-2017, 08:28 PM   #1
slaytonf's Avatar
Trade: General
Rewards Points: 2
This is the surface of a slab just poured for me. I've never seen this before. What's going on?
slaytonf is offline
Old 09-08-2017, 10:38 PM   #2
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Builder/GC
Rewards Points: 180
Re: Concrete Slab Surface
Have you used this sub before?
What kind of trade is "general"?
Are you actually a contractor?
Did you post an intro?
Have you had the slab tested for Leprosy?
Delta
I have an Edifice Complex.
The Following 3 Users Say Thank You to Seven-Delta-FortyOne For This Useful Post:
A&E Exteriors (10-11-2017), Californiadecks (09-09-2017), NJGC (09-08-2017)
Old 09-09-2017, 01:05 AM   #3
GC/carpenter
Californiadecks's Avatar
Rewards Points: 8,338
Delta
I've seen my share of slabs, I can tell you that's leprosy.
Mike.
_______________
Californiadecks is online now
The Following 6 Users Say Thank You to Californiadecks For This Useful Post:
asevereid (09-09-2017), dcustar (10-11-2017), DerrickConcrete (10-10-2017), fjn (09-09-2017), Rio (09-16-2017), Seven-Delta-FortyOne (09-09-2017)
Old 09-15-2017, 10:11 PM   #4
JBM's Avatar
Trade: Masonry
Rewards Points: 4,490
they troweled in the bleed off be my guess
JBM is online now
Old 09-15-2017, 11:04 PM   #5
Mordekyle's Avatar
Rewards Points: 3,296
How much did it cost to get the camo pattern stamped into your driveway?
Mordekyle is offline
The Following User Says Thank You to Mordekyle For This Useful Post:
Old 09-16-2017, 06:12 PM   #6
cdkyle's Avatar
Trade: Concrete & General Construction
Location: The Heartland of the United States of America
Rewards Points: 470
That is awesome looking. I bet that cost extra.
cdkyle is offline
Old 09-18-2017, 08:43 AM   #7
Fishindude's Avatar
Trade: Industrial
Rewards Points: 394
Looks bad and will never look good. If it is a finished floor the buyer will look at forever, it needs to be removed and replaced.
Fishindude is offline
Old 10-10-2017, 09:17 PM   #8
DerrickConcrete's Avatar
Trade: Concrete
Rewards Points: 2
It does look pretty rough... Never had this happen before, but definitely heard of it.
Is it Friday yet?
Derrick
https://www.sfconcrete.com/indianapolis
DerrickConcrete is offline
The Following User Says Thank You to DerrickConcrete For This Useful Post:
CharlieDelta (10-11-2017)
Old 10-10-2017, 10:09 PM   #9
Safety Third
shanewreckd's Avatar
Trade: Concrete Carpenter. Concreepenter? Carpencrete?
Rewards Points: 196
Eh, it'll buff out boys!
shanewreckd is offline
Old 10-11-2017, 07:02 AM   #10
General Contractor
greg24k's Avatar
Rewards Points: 7,348
Was the slab covered with plastic? That would also cause dark and light spots in the area of contact and non-contact, I think there is a term for that it's called "greenhouse effect".
Delayed or early finishing in bleed water would also cause that or hard troweling....
You would also see something like this because of calcium chloride when it retards the ferrite phase of the cement. The ferrite phase tends to remain dark in the presence of calcium chloride and cold weather usually would increase the discolloration effect.
Talk to your contractor who did the job, and find out wtf they did.
greg24k is offline
slaytonf (10-11-2017)
Concrete Slab Foundation Erosion? MandyPRior Concrete & Paving 6 02-08-2016 11:53 AM
Point loads on 4" reinforced concrete slab VanIsle Construction 7 01-26-2016 12:54 AM
Help removing concrete overpour from a concrete slab SpartanTom Masonry 10 07-02-2015 07:17 PM
Repairing a hole on a side of a concrete slab eMaginex Masonry 5 07-12-2013 11:13 PM
Garage slab over existing concrete pjswan Concrete & Paving 1 08-01-2011 02:20 PM
