Concrete Slab Nightmare
Old 07-03-2005, 01:06 PM   #1
scflowstyle's Avatar
Trade: mason
I need to make a 3500 sq ft slab perfectly flat without any hills or valleys whatsoever. It has already been poured. This will be used by a pro bmx bike rider so it can not be wavy but the current slab is wavy. Is there any product that can be poured over the existing concrete slab to even it out so that the finish is PERFECTLY flat.
Any suggestions would be appreciated! This is the 3rd attempt at pouring at flat slab so it can not be re-poured. From end to end it is flat but it has waves.
scflowstyle is offline
Old 07-03-2005, 01:51 PM   #2
jvcstone's Avatar
Trade: Masonry / architectural stone carving
Re: Concrete Slab Nightmare
So just how deep (high) are these hills and valleys??
You might be able to flatten it with some slc (self leveling compound), but not if there are extreme changes.
By the way, I'm not sure that I've ever seen a perfectly flat slab--I'm thinking that would really be rare.
JVC
John VanCamp
www.jvcstoneworks.com
jvcstone is offline
Old 07-03-2005, 05:03 PM   #3
Pro Painter
AAPaint's Avatar
Trade: Painting Contractor
Perfectly level slab? Never seen one in my LIFE! Allthough, when I've seen tilt up panels done some are super smooth...
AAPaint is offline
Old 07-03-2005, 09:21 PM   #4
Teetorbilt's Avatar
I'm a little befuddled why a BMX rider is concerned about a slab but that was not the question.
Old guys used to be able to put down a pretty flat slab. I guess that this is a lost art. As jvc said, there are self leveling compounds, price will go up with accuracy.
Albert Einstein
Teetorbilt is offline
Old 07-04-2005, 10:52 AM   #5
6stringmason's Avatar
Trade: masonry
I dont really deal with slabs on concrete, but I would say if the hills and valleys arent very extreme and are just little pockets, I would think full flex would work. It's relatively cheap and you just add water and mix like plaster. It sets up solid and wont go anywhere for a long time. And dont BMX guys learn how to do that stuff in parking lots anyway.
6stringmason is online now
Help Installing Hardwood over old/new Concrete Slab Hages Flooring 7 06-04-2008 01:02 PM
concrete slab pre-reno Concrete & Paving 14 03-14-2007 11:18 PM
5" pored concrete slab on grade? Nac Masonry 1 04-25-2006 07:53 PM
Hollow steel lally or concrete filled? kusa24 Construction 4 04-23-2006 08:49 AM
Concrete slab per sq ft? nadonailer Construction 1 12-08-2005 04:22 PM
