Concrete Sealing Issue - Masonry - Contractor Talk
Old 02-17-2018, 02:32 PM   #1
PaverSealer's Avatar
Trade: Concrete and Paver Sealing
Hello everyone, Im trying to troubleshoot what happened with this sealing job and could use any advice or thoughts you may have.
I think I got a bad batch of sealer because the job looked great after the prep, then these blotches and streaks came up after the application of the penetrating sealer.
Here are some pics...
Concrete Sealing Issue-img-20171206-wa0003_1518895846527.jpg   Concrete Sealing Issue-img-20171206-wa0004_1518895876963.jpg
PaverSealer is offline
Old 02-17-2018, 02:39 PM   #2
Bull Trout's Avatar
Rewards Points: 46
Re: Concrete Sealing Issue
looks like a shi**y pressure wash job and sealer applied before slab was dry, the guys at the DIY forum can probably help
Bull Trout is offline
Old 02-17-2018, 02:49 PM   #3
The slab is over 15 years old and it had no previous sealer on it before. I'll check with the DIY forum.. thanks
Old 02-17-2018, 05:50 PM   #4
always building
parkers5150's Avatar
Trade: general constructiion
Rewards Points: 2,224
is your sealer solvent based?
"Building trust one job at a time."
www.RDPontheWeb.com
San Diego Contractor Deck and Patio Cover Builder
parkers5150 is offline
Old 02-17-2018, 05:53 PM   #5
No it's water based
Old 02-17-2018, 07:23 PM   #6
always building
cant help you then
www.RDPontheWeb.com
Old 02-17-2018, 07:24 PM   #7
always building
how long after application were photos taken?
www.RDPontheWeb.com
Old 02-17-2018, 07:41 PM   #8
A little over 24 hours...
Old 02-17-2018, 07:54 PM   #9
It's lighten up since the photos but it's still there. The manufacturer said it was because the Portland cement is older
Old 02-17-2018, 08:14 PM   #10
WVHammer's Avatar
Trade: general
Rewards Points: 2
Ive had some of those water based sealers do this before. The cloudiness usually fades after a few days and looks normal.
WVHammer is offline
Old 02-17-2018, 10:08 PM   #11
Thank you for your post.
Any tricks to try and keep this from happening?
Old 02-18-2018, 09:48 AM   #12
always building
i personally believe you need to give it a week or two to let it fully cure and then you will see a more desired result
www.RDPontheWeb.com
Old 02-23-2018, 06:08 PM   #13
Caldecorative's Avatar
Trade: B,C61-D06
Rewards Points: 6
Was the sealer UV stable? Did you back roll it, did you use any type of acids to clean the surface?
Caldecorative is offline
Old 02-23-2018, 06:16 PM   #14
Not 100% sure about the UV but I used a degreaser and cleaner beforehand. I didn't do or use etching or bleach mixes. The application was sprayed on with a battery powered backpack sprayer.
Old 02-23-2018, 08:55 PM   #15
always building
if you didnt roll that then what i would bet what you're looking at is the shadows of a previous power wash!! sealers often "enhance" the substrate below....the next time you want to do a seal, I think part of your initial due diligence would be spraying a bit of water on the floor and see whats rears it's head???
www.RDPontheWeb.com
Old 02-23-2018, 09:13 PM   #16
Ya I'll give it a shot. Thx for the tip!
Old 02-24-2018, 09:47 AM   #17
always building
re read
www.RDPontheWeb.com
Old 03-26-2018, 09:28 PM   #18
Genius HardScaper
GC_contractor's Avatar
Trade: Masonry and hardscaping
Rewards Points: 58
You can eliminate streaking cause by pressure washing by using a "turbo" or rotating nozzle.
http://www.aaacorn.com
GC_contractor is offline
Old 04-03-2018, 05:22 AM   #19
NYCB's Avatar
Trade: Concrete/Masonry
Rewards Points: 242
Use solvent based next time.
NYCB is offline
Control joints in concrete foundation walls fjn Masonry 45 04-06-2015 08:52 PM
Help Thinking outside the box here... CONCRETE HELL!! JeremyBCalnan Tools & Equipment 37 06-24-2014 10:33 PM
Lightweight concrete alternative in a condo DanFreysinger Flooring 17 11-14-2012 10:10 AM
