Concrete Saw For Residential Basement Floor Cutups
Old 11-04-2017, 04:45 PM   #21
tgeb's Avatar
Rewards Points: 764
Re: Concrete Saw For Residential Basement Floor Cutups
I have a Husqevarna electric 14" saw for indoor work. I always bring my own power to the site after having a breaker popping issue on a site that had me ready to throw the saw through the window.
We used a gas saw to cut an opening in a foundation, from the outside, and still set off the smoke detectors in the house.
www.gebcon.com
tgeb is online now
Old 11-04-2017, 04:54 PM   #22
Jonbuild's Avatar
Trade: Log home builder
Rewards Points: 422
I had a project a few months ago, I built a tent around the area that was to be cut, I had a demo fan air in and another fan out, with gas cutoff saw, water, and a shop vac, and even with gass mask, I felt wossie that night,
Jonbuild is online now
The Following User Says Thank You to Jonbuild For This Useful Post:
fjn (11-04-2017)
Old 11-05-2017, 06:49 AM   #23
NJGC's Avatar
Location: Unfortunately I live in the communist republic of NJ.
Rewards Points: 78
Originally Posted by battering ram View Post
im a plumber and typically use an electric jack hammer to bust up floors. We constantly run into really hard concrete. Im considering buying a concrete saw. Im looking at a Husqvarna k760
how would a gas saw work in a residential basement?
it needs a hose hookup..which could also be an issue in a residential basement...would a spray jug by a 2nd person work?
electric saws get bad reviews....otherwise thats probably a smarter way to go...
ive got a few jobs coming up where i need something more than a jackhammer and dont want to spend 8 hours jackhammering
advice?
The K760 is actually a really good saw for indoor use. Virtually no dust and only leaves a very small trail of slurry no puddles or big mess. Only thing you have to do is make sure you are on a 20 amp breaker as the saw draws 15 amps. If the home I'm working in doesn't have a 20 amp available I install one or bring my generator.
Any of you dumb dumbs that run a gas tool indoors should seriously reconsider. You are supposed to be professionals so let's conduct ourselves that way. Carbon monoxide can linger in the home long after your done and possibly affect other occupants of the house.
Sent from my SAMSUNG-SM-G930A using Tapatalk
NJGC is offline
The Following User Says Thank You to NJGC For This Useful Post:
EthanB (11-05-2017)
Old 11-05-2017, 09:04 AM   #24
Talking Head
EthanB's Avatar
Rewards Points: 36
I always sub it out. I mark up the sub. So I see this as two options:
1. Check-in before and after the process, make some money and go work at a different site or in the office while the sub does the work.
2. Spend 4-8 hours on grueling, backbreaking work that I absolutely hate and make the same amount of money, IF all goes according to plan.
Option 1 all day, baby.
Planer.....
EthanB is offline
The Following 2 Users Say Thank You to EthanB For This Useful Post:
MarkJames (11-06-2017), overanalyze (11-05-2017)
Old 11-05-2017, 11:42 AM   #25
Master Mason
RacinMason's Avatar
Trade: Masonry
Rewards Points: 110
Someone usually only breathes 2stroke fumes once in a home, that stuff lingers for days.
I like the sub it out idea!
650cc on the track
800cc on the snow
1000cc on the street
RacinMason is offline
Old 11-05-2017, 12:00 PM   #26
cedarboarder's Avatar
Trade: Workaholic
Rewards Points: 886
Originally Posted by jlhaslip View Post
Go ahead and use the gas saw. You will only do it once. Guaranteed.
They don't make masks for running a gas saw in confined spaces.
Just like Seven said. Don't ask me how I know.
Hydraulic wet saw all the way.
Yup. I've never done it until I was working for another company.
It was embarrassing! HO was complaining of the smell on 2nd floor.
I ended up getting laid off for refusing to work.
I have not done a thread on this company yet... too much to write.. haha
cedarboarder is offline
The Following User Says Thank You to cedarboarder For This Useful Post:
asevereid (11-06-2017)
Old 11-05-2017, 12:39 PM   #27
Pearce Services's Avatar
Trade: Commercial Loading Dock and Door Contractor
Rewards Points: 42
Are you cutting all the way through? I have found that cutting all the way through is not always necessary. I remove a section by cutting all the way through, but after the first piece is out, scoring and sledge hammering so it looks neat on the surface is adequate. Pulling dirt out from underneath the area you are hammering helps to break it out.
Kevin
www.BadcoDoors.com
Pearce Services is offline
Old 11-05-2017, 04:54 PM   #28
Master Mason
RacinMason's Avatar
Trade: Masonry
Rewards Points: 110
Good idea.
650cc on the track
800cc on the snow
Old 11-05-2017, 09:23 PM   #29
battering ram's Avatar
Trade: plumber
Rewards Points: 208
thanks to all for the good advice
ive got the gas saw out of my consideration
i think for now we will just keep jack hammering, but for the garage job that turns into living space---ill rent a walk behind to try it out....no way im hammering 4+" of concrete with steel reinforcement.......its a large area too......i can open windows and make a mess
battering ram is offline
Old 11-06-2017, 06:48 AM   #30
tgeb's Avatar
Rewards Points: 764
I used an air powered walk behind on a project, it worked well once we figured out that 150' or so of hose was too much, the saw had no power. When I called the rental place to complain they said it doesn't work well with over 50' of hose.
I said thanks for telling me when I asked you to send it out with 200' of hose.
We had to hand walk the compressor through the customer's yard to get close enough.
www.gebcon.com
tgeb is online now
Old 11-06-2017, 07:52 AM   #31
rustyjames's Avatar
Rewards Points: 1,532
Curious, Has anyone tried the Hilti system?
https://www.hilti.com/cutting%2c-saw...c-cutter/r3941
rustyjames is online now
Old 11-06-2017, 08:16 AM   #32
Master Mason
RacinMason's Avatar
Trade: Masonry
Rewards Points: 110
I have not tried that saw, but it looks good, and being a Hilti, I'm sure it's a great tool.
650cc on the track
800cc on the snow
The Following User Says Thank You to RacinMason For This Useful Post:
rustyjames (11-06-2017)
Old 11-06-2017, 11:51 AM   #33
Trade: Workaholic
Rewards Points: 886
Its been mentioned a couple times
Old 11-06-2017, 11:54 AM   #34
NJGC's Avatar
Rewards Points: 78
I've tried the hilti system and IMO it's crap. 2 much dust escapes the vac system and even the self cleaning filters become clogged to quickly.
NJGC is offline
Old 11-06-2017, 02:07 PM   #35
JBM's Avatar
Trade: Masonry
Rewards Points: 4,390
Ill take that bet, never underestimate the dumbness of some masons.....
JBM is offline
The Following User Says Thank You to JBM For This Useful Post:
Fouthgeneration (11-06-2017)
Old 11-06-2017, 03:22 PM   #36
Windycity's Avatar
Trade: Masonry
Rewards Points: 5,738
I would suggest trying using a dust deputy. Cutting concrete produces an incredible amount of dust and when you lose suction obviously it will create a lot of dust.
Windycity is online now
The Following 2 Users Say Thank You to Windycity For This Useful Post:
rustyjames (11-06-2017), superseal (11-06-2017)
Old 11-06-2017, 04:22 PM   #37
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 6,209
NJGC @ # 23: Your are confusing a 2 stroke K760 (76cc) gas 14" demo saw with the K 3000 Wet ( has a GFI in the cord assembly) a 14" electric ~15 Ampere 120 volt saw.
https://hgcdn2.azureedge.net/qs_mh=460&mw=460&ver=00000000T000000/_$$_/media/dam/husqvarna%20construction/200%20%20handheld%20power%20cutters%20%20power%20p acks/electric%20power%20cutters/2014/12/03/10/39/hc210-0258.ashx
Fouthgeneration is offline
Old 11-06-2017, 04:42 PM   #38
Trade: Workaholic
Rewards Points: 886
That's why they have wet saws. blades last longer too.
Pouring concrete over new basement pipes jacselee Plumbing 7 03-26-2014 09:52 PM
Considerations for pouring a rather tall concrete pier? acro Construction 20 04-23-2013 09:04 PM
Spray Foam not adhering to concrete basement wall... Paint & Hammer General Discussion 6 11-04-2012 12:39 PM
Wet basement, just making sure my thoughts are correct HandicappedHome Excavation & Site Work 7 10-12-2012 06:17 AM
Basement footings/walls poured wrong, now basement leaks, no sump installed Utah Ryan General Discussion 11 09-20-2012 06:04 AM
