Concrete Saw For Residential Basement Floor Cutups - Masonry - Contractor Talk
Old 11-03-2017, 02:49 PM   #1
battering ram's Avatar
Trade: plumber
Rewards Points: 208
im a plumber and typically use an electric jack hammer to bust up floors. We constantly run into really hard concrete. Im considering buying a concrete saw. Im looking at a Husqvarna k760
how would a gas saw work in a residential basement?
it needs a hose hookup..which could also be an issue in a residential basement...would a spray jug by a 2nd person work?
electric saws get bad reviews....otherwise thats probably a smarter way to go...
ive got a few jobs coming up where i need something more than a jackhammer and dont want to spend 8 hours jackhammering
advice?
battering ram is offline
Old 11-03-2017, 03:09 PM   #2
fjn's Avatar
Trade: mason
Rewards Points: 9,362
Re: Concrete Saw For Residential Basement Floor Cutups
As much as I love gasoline chop saws,I would not run one in a basement. I would probably use one of these https://www.amazon.com/Evolution-DIS...70_&dpSrc=srch
With a real good shop vac. with a dust deputy cyclone separator.
fjn is offline
Old 11-03-2017, 03:12 PM   #3
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Builder/GC
Rewards Points: 472
The water isn't an issue if you use a shop-vac.
The exhaust will burn your throat and eyes and lungs. For days. Even with what you think is good ventilation.
Don't ask me how I know this.
Delta
Get Off My Lawn.
The Following 3 Users Say Thank You to Seven-Delta-FortyOne For This Useful Post:
fjn (11-03-2017), overanalyze (11-03-2017), SouthonBeach (11-07-2017)
Old 11-03-2017, 04:19 PM   #4
Windycity's Avatar
Trade: Masonry
Rewards Points: 6,008
Having somebody stand there with the sprayer does not totally eliminate dust
Probably only 85% of it so 15% in an enclosed space is a lot
You need to completely flood the blade in order for it to be mostly dust free
I have the husqurvana electric saw And it works good however it does not have nearly as much power as the gas saw so I would not want to cut through a lot concrete with it. And it uses a lot of power and has a tendency to blow circuit breakers
Windycity is online now
The Following User Says Thank You to Windycity For This Useful Post:
tgeb (11-04-2017)
Old 11-03-2017, 04:43 PM   #5
Trade: plumber
Rewards Points: 208
so how would you handle it?
stick with 8 hours with a jack hammer?
ive got a project coming up where they turned a garage into living space...so im looking at 4" with metal to bustup....its miserable work...
i may hire out to cut if i cant come up with a solution that works....new homes basement floors bust up like nothing...but old ones are a b*itch
Old 11-03-2017, 04:51 PM   #6
Trade: Builder/GC
Rewards Points: 472
Hydraulic saws are the king.
Fire/Rescue teams use them everywhere, indoors, hazardous environments, in the rain, whatever.
They are a little pricey, and you need a hydraulic power unit to run them, but, hey...... They're awesome.
Delta
Get Off My Lawn.
Fouthgeneration (11-04-2017)
Old 11-03-2017, 04:54 PM   #7
Mike-B's Avatar
Rewards Points: 662
http://www.diamondproducts.com/Produ...AW/CC1500.aspx
OR
http://www.diamondproducts.com/Produ...CC1300-XL.aspx
My local rental shop has the 1300 for $100/day. Haven't tried it yet.
Mike-B is offline
Old 11-03-2017, 04:56 PM   #8
Sure, I can do that...
jlhaslip's Avatar
Trade: carpentry/renovations
Rewards Points: 190
Go ahead and use the gas saw. You will only do it once. Guaranteed.
They don't make masks for running a gas saw in confined spaces.
Just like Seven said. Don't ask me how I know.
Hydraulic wet saw all the way.
jlhaslip is offline
The Following User Says Thank You to jlhaslip For This Useful Post:
MarkJames (11-03-2017)
Old 11-03-2017, 05:00 PM   #9
Trade: Builder/GC
Rewards Points: 472
J
Unless you want to use full-blown SCBA.
Delta
Get Off My Lawn.
Old 11-03-2017, 05:12 PM   #10
Windycity's Avatar
Trade: Masonry
I have used a gas saw in a basement but used air movers to properly ventilate it.
It was ok since we had plenty of airflow
Jonbuild (11-04-2017)
Old 11-03-2017, 05:19 PM   #11
Renaissance Man
superseal's Avatar
Rewards Points: 5,478
Sub it out if you don't have the proper equipment and don't enjoy doing it.
Full blown 90 lb air driven jackhammers are a lot quicker than electric...walk behind basements saws can be rented and is proper protocol. Invest in dust containment systems...you need them in this environment.
My average 100ft interior french drain systems are usually busted out by noon...it's getting all the chit out of there that I hate. Conveyors are your friend here.
supersealconstruction.com
superseal is online now
The Following User Says Thank You to superseal For This Useful Post:
Old 11-03-2017, 05:57 PM   #12
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 13,416
Allow me to introduce the breaker popper:
Inner10 is online now
Old 11-03-2017, 06:06 PM   #13
Trade: Builder/GC
Rewards Points: 472
With a 23 amp motor, it's not gonna work in a standard outlet.
Delta
Get Off My Lawn.
Old 11-03-2017, 06:10 PM   #14
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 13,519
Sub it to the best and don't look back. It's one of those things that's beyond totally worth it.
MarkJames is offline
Old 11-03-2017, 06:39 PM   #15
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 2,449
Same here, but it still stinks the house up. I rent an electric and make sure I can plug into a 20A circuit.
And use a garden hose attached to the saw, with a helper on shop vac duty.
Tinstaafl is offline
fjn (11-03-2017)
Old 11-03-2017, 06:59 PM   #16
Windycity's Avatar
Trade: Masonry
Here is my electric which I use indoors but no way would I use it to cut a concrete floor. That would be miserable for more than a foot or two. It just doesn’t have the power plus after a few minutes I wouldn’t be able to stand up since my back would be in A locked position. Most electric saws are not ergonomically designed to cut floors
Old 11-03-2017, 07:02 PM   #17
Inner10's Avatar
Delta
Hence why I call it the breaker popper...
It has a 20A twist lock end but comes with a 15A adapter....don't even think of plugging it into a vac....you really need a 20A supply and another breaker for your vac.
Sent from my Nexus 6P using Tapatalk
Old 11-03-2017, 07:22 PM   #18
Capra aegagrus
Tinstaafl's Avatar
Well yeah, they work much better with a blade in them.
For your back, you can use a walk-behind model. But that pretty well limits you to floors only. Either way, I'm too cheap to buy one. For my limited usage, I just rent whatever I need for a given job.
Fouthgeneration (11-05-2017)
Old 11-04-2017, 08:13 AM   #19
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 6,671
A four stroke concrete floor wet saw with two or more Large fans, one in one out, works faster straighter, and much easier on the backs....
the straight and deeper the less the patch work required.
Also catalytic converters can be installed that grossly reduce toxic fumes after warm up, ( warm up out doors if possible)
remember a slight angle(wider at the top of cut) if possible on one side makes the spoil come out easier....
Plan ahead for fittings and finger room. Generally any less then 12-16" away from a wall will break off any way.... but allow for wavy oversized footers....
If I owned a skidder, fork lift, or mini hoe with a hydraulic optional circuit, I'd install a Hydro motor on an old 8 to 13 HP target floor saw to use cutting indoor concrete, and buy a hydraulic concrete chain saw if I did alot of floor demo.....
Or air powered if I owed a ~100 CFM towed compressor......
Fouthgeneration is offline
The Following User Says Thank You to Fouthgeneration For This Useful Post:
overanalyze (11-04-2017)
Old 11-04-2017, 04:13 PM   #20
Windycity's Avatar
Trade: Masonry
Originally Posted by Tinstaafl View Post
Well yeah, they work much better with a blade in them. .
Damm I was wondering why that saw didn’t cut worth a chit! Haha
Common i am too cheap to have enough blades because I have 4 saws and rarely have more than 2 saw blades!
The Following 2 Users Say Thank You to Windycity For This Useful Post:
Fouthgeneration (11-05-2017), Tinstaafl (11-04-2017)
Pouring concrete over new basement pipes jacselee Plumbing 7 03-26-2014 09:52 PM
Considerations for pouring a rather tall concrete pier? acro Construction 20 04-23-2013 09:04 PM
Spray Foam not adhering to concrete basement wall... Paint & Hammer General Discussion 6 11-04-2012 12:39 PM
Wet basement, just making sure my thoughts are correct HandicappedHome Excavation & Site Work 7 10-12-2012 06:17 AM
Basement footings/walls poured wrong, now basement leaks, no sump installed Utah Ryan General Discussion 11 09-20-2012 06:04 AM
