Newbie
Trade: Home Renovations
Concrete Or Masonry Walls In Tight Space
Hi everyone...I could use some help.
We started excavation and poured footers for an addition. The design includes a stairwell so they can have access to their basement from inside. In my estimate I planned for block walls, not realizing they'd need to be parged and coated. (This is the first foundation work we've done.) My reasoning for doing block walls was that there isn't really space to excavate much wider than the footers. I initially figured block walls would work best because they could be layed from inside. The parging and coating presents difficulty because of how tight the excavation is. A couple of questions: 1) If we pour concrete using SIP forms...does this eliminate the need to do a water-proofing coat from the outside? 2) Are there SIP forms that don't have to be braced from the outside of the wall? 3) How expensive are these things? (SIP forms) Thanks, Kevin
Proverbs 18:9 "One who is slack in his work is brother to one who destroys." |
Re: Concrete Or Masonry Walls In Tight Space
How deep?
How tight? What do guys in your area who do basement walls say? Only "for sure" is basement walls need waterproofing outside. As well as foundation drainage.
Newbie
How deep? - about 6 1/2 feet
How tight - about 8 inches...I'm pretty sure it will be too tight for anyone to squeeze in there to work. I figured that with the SIP forms there was no way to do any water proofing. Do the forms have some sort of integrated barrier? Thanks, Kevin
As far as I know, everything needs some
type of waterproofing. I've always used 3' over-dig... consider 2' to be tight! Some one has to get in there to do drainage anyway. Go back and at least "step" the banks. Unless you've got some W/P and drainage Elves.
Your mason can parge the exterior as he builds the wall by reaching over every couple courses.
Water proofing can be rolled or sprayed on from ground level. Drainage can be provided by backfilling with crushed stone or gravel. I don't know what sip forms are but I do know that typical concrete forms need more space than you have there so they can be removed. |
I'm a Mac
Trade: ICF Construction
Tgeb got it, the mason can parge as he goes, or you can do ICF's (Is that what you were thinking of? Not Sips) as the block goes up every course you have peel and stick already cut and roll it up a block at a time. When finished hang a dimple board from the top the same as how you hang curtains. Don't forget the weeping tile, install it prior to starting the blocks, once everything is complete (Walls, Waterproofing) get the gravel in.
Chris |
DRIFTWOOD
Trade: GEN CONTR.
Why are You limited to 8". You also need schedule 35 perforated pipe and filter fabric. This sounds like a LEAKY BASEMENT that will come back to haunt YOU.
#8 | |
Re: Concrete Or Masonry Walls In Tight SpaceQuote:
I don't get how the membrane sticks to the wet parging. Did I miss something?
I'm a Mac
The membrane sticks to ICF blocks, not parging on CMU's
Chris |
Ok! I did miss the little jump there
Never used the ICF. Still the 8" seems tight... better he than me!
I'm a Mac
Actually I have done this, work in a major city and you get to build on zero lot lines, this is the only way to do it.
Get the neighbors permission to excavate and let them know you will be encroaching on their property, do this with a bottle of wine and a gift certificate to a nice steak house. So far it's worked every time. Build and pour the wall already waterproofed and when done have the guys backfill with 5 gallon pails!!!
Chris |
Uh huh, right...
better thee than me. ![]() Yet another reason I am happy not to do residential in a big city. BTW, Where are you? In Napa Valley? Or actual city of Napa?
I'm a Mac
I'm in the City
Work throughout the valley and it's surrounding areas
Chris |
Parge the blocks before laying them, parging the joints as you go up.
#15 | |
Newbie
We did use masonry, the mason did parge the exterior just as you described. The waterproofing was sprayed on. Thanks!
| concrete walls finishing | mjay | Masonry | 2 | 03-05-2009 03:36 PM |
| Why Build ICF | monsterconstruc | Green Building | 32 | 09-28-2008 11:48 PM |
| Non-retaining concrete walls | calypso | Masonry | 10 | 07-23-2007 08:55 PM |
| Bridging for above grade Concrete Walls | ETHICS05 | Construction | 1 | 11-21-2005 12:43 PM |
