Trade: Built two houses and flip houses
Concrete Block Installed Out Of Level
I tore down a small addition to rebuild on the existing block foundation. Upon exposing the concrete blocks I found that it was 3 inches out of level. It appears it did not settle because it had shims to make it level initially. (homeowner constructed badly) Is it possible to install a level form and pour concrete into the top course and above it to level?
Jeff |
Trade: custom home building
Re: Concrete Block Installed Out Of Level
sure
Trade: Masonry
Yes
welcome, and yes
Around here that would have to be done with non -shrink mud. I would think ripping down the sills would be alot faster on a small addition. If you set up something on your bench to hold the 2x straight you should be able to rip from both sides with a regular skil saw.
definately
Trade: Masonry
Attach plywood forms to each side with tapcons. Be sure to shoot the tops in with a laser to get it good and level. Be careful with the concrete you use - it needs to have a high slump (9" - 11") to allow for the water that the block will absorb from the mix. See ASTM C476 for more details. Good luck.
Regards |
#8 | |
Re: Concrete Block Installed Out Of LevelQuote:
agreed ![]() ![]()
tap con a 2x8 or plywood from 3 in. to nothing, go into cores 4 or 5 inches, pour, tap forms, stick some anchor bolts in
As long as the tapered end of your concrete is of sufficient thickness. You may consider cutting the block.
#11 | |
Trade: masonry
our town is outa control here.shi%$y inspector shut down the pizza hut remodel,because the plans dont have a stamp on them. went up with four cops to shut em down.
life is short,do your masonry naked!! http://ok.local.yahoo.biz/knabemasonry/index.html |
| Glass Block Transition | Paul_NJ | Ceramic & Stone Tile | 0 | 03-15-2007 08:14 AM |
| Basement Block Question | TBALL | Construction | 11 | 02-09-2007 06:40 PM |
| What are your thoughts on this foundation block? | rino1494 | Masonry | 14 | 01-09-2007 05:35 PM |
| Concrete bid | csol | General Discussion | 3 | 10-05-2006 09:22 PM |
