Trade: Masonry
Comparing Strategies In Masonry
I would like to discuss not only different strategies but also problems that have been solved and problems that we would like to solve the world of Masonry.
Since it is not very productive or profitable to analyze which way works best while on the company clock I thought that this is the appropriate place to exchange our ideas and opinions. |
Trade: Masonry
Re: Comparing Strategies In Masonry
If you have to cut a control joint in a brick wall try putting two blades on your quickie saw.
Trade: Masonry
If you are 5 jacks high in the air and outriggers are too close to your wall (or too far away) make sure the screwlegs on the jacks that are next too the problem jack are snug (BE CAREFUL and make sure the scaffolding is plumb) then loosen the screwlegs on the problem jack so that the jacks that are adjacent to it are supporting it allowing the jack to swing freely back and forth. Position the scaffold feet in the correct position then tighten screwlegs.
Trade: Masonry
If you are doing a job with no place to dump your mixer clean out ,then after dump your last batch of mud do not put water in it. Banging out the leftovers is easier when its dry than when its wet.
Confucious says, "Mason who cut stone without dust mask and water, wake up with black lung".
Trade: masonry
if someone working for me was to try that,they wouldnt be working for me the next day.if there is no place to dump,you can make a sand dam and dump there.picking it up after it dries.
life is short,do your masonry naked!! http://ok.local.yahoo.biz/knabemasonry/index.html |
Trade: Concrete & masonry
Re: Comparing Strategies In Masonry |
#8 | |
Trade: Masonry
Re: Comparing Strategies In MasonryQuote:
I was meaning a that job was finished and you no reason to come back like a mailbox for instance that was on the other side of town. Forgive me for not being clear. |
Trade: Masonry
When you purchase a new mixer do you adjust the blades so that they touch the drum?
#10 | |
Trade: Landscape contractor
not a good idea. Perhaps applicable to a concrete mixer but cleaning the paddles on a mortar mixer is a PITA when dry. Banging not good.
Speaking of cleaning mort mixers, I'm wondering if any of you run plastic drummed mixers. I'm in the market for a new mixer (to replace little 6 CF), & wondering if they clean alot faster than steel? It seems I could buy another 8 CF mixer in a plastic drum that only weighs what a 6CF steel weighs.
#12 | |
Trade: Masonry
When I said dry I meant let it set up for 30 minutes not hardened, and if I have limited water I bang then scrape then rinse. If you dump water in the mixer after the last batch the mud sticks to the drum and blades when you get ready to clean it out. |
Trade: masonry
My Stone mixer is 5 years old. Still starts on the first pull everytime, and alot of smaller jobs I do I cant get a hose and have to cart buckets of water from the neighbor.
There for I cant keep my mixer as clean as I want, but I have no qualms about beating on it, and have done so any many occasions. Granted I dont take my 5lb stone hammer to it and pound a hole in the side, but theres nothing wrong with givin it some TLC.
Kamps Masonry & Concrete Countertop Design Green Bay, WI 920-680-3195 Visit our website @ http://www.concretecountertopsdesign.com/ |
Trade: Design
A garden hoe with a small blade and a long handle works great for getting the last of the concrete out and cleaning the mixer.
#15 | |
and of course NuShine wax every other day.
"The problem with internet quotes is, you never know if they are authentic." -Abraham Lincoln- Less with the jaw more with the paw! |
Add 1/2 to 3/4 of your mix water for the next batch and run the mixer for a few minutes, and it is clean for a couple of hours. Put the used bags in the pour out zone, wet them and throw the whole mess away at end of the day, or at the end of the job if it is small.
It ain't Rocket Science unless you are building rockets. |
Trade: Masonry
Anyone ever layed caststone with pins in the head joints ?
#18 |
Trade: Bricklayer
Yes many times.
#19 |
Trade: Masonry
So you know how to lay the closer and still be able to put the pins in on both sides?
#20 |
Trade: Bricklayer
Pins who needs 'em. I assume you are talking about the old string line trick? I use that on large precast panels even if it is not the closure panel.
| MK-BX 4 masonry saw? | denver 2 | Masonry | 13 | 09-12-2009 01:49 PM |
| How to Seal White Mortar Masonry | ScottLewis | Masonry | 2 | 03-21-2009 07:50 PM |
| SCR Masonry guide systems | INTRA | Masonry | 0 | 12-27-2008 01:55 PM |
| Masonry lowset support system for a house!? | canet2007 | Construction | 4 | 09-16-2008 08:33 PM |
| removing doorway from solid masonry wall | Jamison | Remodeling | 3 | 08-15-2008 06:23 PM |
