Trade: Finish Carpenter
Colored Mortar
I need to do some mortar patch work around my sisters new window. The mortar is very dark gray (almost black). I was planning on adding a colorant top the mortar to match the color. Will the mortar be darker or lighter in color when it drys?
Re: Colored Mortar
2X lighter when dry is my rule of thumb.
Re: Colored Mortar
Thanks for the info.
OsNap
Guest
Posts: n/a
Re: Colored Mortar
You could also mix a small amount up and see how it dries and go from there.
Re: Colored Mortar
You can also make a smear on a piece of wood and blow dry it (or use the exhaust pipe of your truck).
Re: Colored Mortar
Mix some samples and let them dry 7 days.Use your wife's best measuring cup for water,sand and cement,measuring spoons for color.This is best done under controlled conditions.The coffee table in the living room is a good place.That way you don't miss any games on T.V.Best of luck.
#7 | |
old school
Trade: stone masonry
Re: Colored MortarQuote:
Trade: Ornamental Plasterer/Restorer
Re: Colored Mortar
Spray a water on the existing mortar and make your new mix look like wet original mortal. When it drays you have that same color.
Shame on me. It is 3 years old post. Last edited by Resta; 02-14-2009 at 03:52 PM. |
Trade: masonry
Re: Colored Mortar
huh!
![]() D. |
| Mortar Bedding for Stone on Concrete Question. | lukachuki | Masonry | 10 | 05-26-2007 10:09 PM |
| brick and mortar | jshuatree8 | Masonry | 6 | 04-25-2007 09:37 PM |
| Changing mortar color? | kcrossley | Masonry | 1 | 12-17-2006 01:44 AM |
| Mortar too white | locofoco | Construction | 2 | 01-29-2006 05:31 PM |
| Mortar Matching Service | lukachuki | Masonry | 9 | 01-06-2006 10:22 PM |
