CMU Blocks 2hr Fire Resistance
Old 02-12-2009, 08:58 AM   #1
jjwee's Avatar
Trade: Main Contractor
Hi,
I am working in asia, specific will be Singapore. Now I am doing a project with dilemma.
The project I am handling now requires the used of Aerated Lightweight Concrete and Concrete Masonry Unit. Both blocks have different characteristics.
ALC do not satisfy the point load capacity, while CMU, not all sizes gives a minimum 2 hr fire resistance. As the project requires the test reports of 90mm, 140mm and 190mm CMU block 2hr FR. I could only manage to get the 140 and 190. Have no more leads to find the other test report.
As for the ALC, what are the point load capacity. And does the CMU blocks require infill to work better? How about CMU point load?
JJ
jjwee is offline
Old 02-12-2009, 09:20 AM   #2
Tscarborough's Avatar
Re: CMU Blocks 2hr Fire Resistance
Contact your local supplier as any information relating to these 2 specific properties will rely upon the materials used in that location.
Tscarborough is online now
Old 02-12-2009, 09:31 AM   #3
concretemasonry's Avatar
Trade: Masonry consultant
Your ALC or AAC will have a strength that is always lower than a CMU.
The strength of the AAC depends on the density of the concrete and in some cases the manufacturing methods. Contact the supplier for the accurate information.
Dick
concretemasonry is offline
Gas Flex running through the wall of fire place acrwc10 Plumbing 6 12-07-2008 11:14 PM
New Code Coming dayspring Business 33 10-04-2008 06:08 PM
Fire cleanup Loghome54 HVAC 0 03-12-2008 12:02 PM
CMU Blocks per man under 'ideal' conditions personalt Masonry 15 07-28-2006 07:06 PM
Where's my thread? (Politics anyone?) AAPaint Off Topic (Non Trade) 175 08-16-2005 01:45 AM
