Cleaning Concrete
Old 06-13-2006, 06:59 PM   #1
S.W.C's Avatar
Cleaning Concrete
Hi
Does anyone know of anything that will remove tire marks from a concrete driveway.
The drive was poured last year, and it has fairly smooth finish on it, so it really shows the tire marks.
I was going to used dilluted muriatic acid, and pressure wash it, but I'm not sure if that'll get the tire marks off.
Someone said they used brake cleaner on their walk to remove tire marks, but it was painted.
Is their anything that will loosen the rubber up enough so I can pressure wash it off?
Thanks
S.W.C is offline
Old 06-13-2006, 08:25 PM   #2
Tscarborough's Avatar
Re: Cleaning Concrete
Acid won't have any effect on rubber, I can tell you that.
Tscarborough is online now
Old 06-13-2006, 08:27 PM   #3
tkle's Avatar
Acid will only etch it.and if anything make it stand out more.Possibly tri sodudium phosphate and a good scrub.Keeping concrete wet while driving on it with heavy loads such as a forklift will keep the black marks from sticking.
tkle is offline
Old 06-13-2006, 08:54 PM   #4
6stringmason's Avatar
Trade: masonry
Gas will take the rubber off if I remember correctly. I think my cousin and I used it once when we were 15 and put a couple of blackies on his old mans driveway with the old Crown Vic police car lol. Good times... good times. Althought it didnt get all if it off, it did get quite a bit.
Kamps Masonry & Concrete Countertop Design Green Bay, WI
920-680-3195
Visit our website @
http://www.concretecountertopsdesign.com/
6stringmason is offline
Old 06-13-2006, 09:27 PM   #5
S.W.C's Avatar
I'm hoping the pressure washer will get a lot of it.
The TSP sounds like a good idea, I've gotten a lot of things off with the liquid form.
I'm a little wary of using gas, the price for one, the environmental impact, and then theirs the danger of getting turned into a crispy critter.
I'll probably go with TSP and scrubin, before pressure washing.
If that doesn't work, I'll try the brake cleaner.
Thanks
S.W.C is offline
Old 06-13-2006, 09:43 PM   #6
Rubber isn't a "stain" per se, so mechanical action will usually get it off. TSP and elbow grease and a pressure washer should do it.
Old 06-30-2006, 11:56 PM   #7
Phil Graves's Avatar
Trade: Interlocking Concrete Pavers
Many chemical companies make rubber removing solutions. Techni-Seal (my company) and ProSoCo are two that I know of that have effective products, and they're pretty inexpensive as well. Feel free to PM me if you want more info.
Phil Graves is offline
Old 10-24-2006, 05:47 PM   #8
Timd's Avatar
Trade: Housing
Phil is that you
Tim D Ontario Can.
Timd is offline
Old 10-24-2006, 07:06 PM   #9
Squrtgun's Avatar
Trade: Pressure Washing
You can use a buytl based cleaner in conjunction with your pressure washer to remove tire mark.
Purple Power and castroil Super Clean are 2 that are readily available at auto parts store.
Squrtgun is offline
Old 10-25-2006, 08:03 PM   #10
OsNap
Guest
OsNap's Avatar
Posts: n/a
When I cleanedm y patio and apron I used my pressure washer and some commerical grade soap, and it work prety good. Try that out and see if it works.
Cleaning Concrete driveway pitterpat Pressure Washing 20 05-21-2011 11:09 AM
Pressure washing 2300 sf concrete pitterpat Pressure Washing 13 09-28-2010 08:16 PM
Staining concrete ryan.s Masonry 12 03-05-2009 03:54 PM
structural concrete... mdshunk Masonry 3 03-05-2009 03:42 PM
Cleaning concrete off of mixer. Michaeljp86 Masonry 25 07-08-2007 11:11 AM
