Clean Mortar Off Of Glass Block???
Old 02-21-2009, 09:43 PM   #1
Nobreus's Avatar
Trade: General Contractor, Carpenter
Wonder if anyone has experience with cleaning white mortar off of glass block? I need to take apart an existing shower wall, 7 feet by 8 feet long, because the first installer used mortar instead of silicone, and i am wondering if it's cost effective to try and clean the glass blocks from very cured mortar? And also if anybody has experience with using silicone for such a large wall?
Thankful for answers, Marcus
Nobreus is offline
Old 02-21-2009, 09:54 PM   #2
Brickie's Avatar
Trade: One on top of Two
Re: Clean Mortar Off Of Glass Block???
steel wool, putty knife/scraper, etc.,
“Ron Paul is one of the outstanding leaders fighting for a stronger national defense. As a former Air Force officer, he knows well the needs of our armed forces, and he always puts them first. We need to keep him fighting for our country.” – Ronald Reagan
Brickie is offline
Old 02-21-2009, 10:50 PM   #3
NJ Brickie's Avatar
Trade: Bricklayer
Might want to try this product.
http://www.prosoco.com/ProductDetail.asp?ID={CEAEC215-D360-4B2E-BB9C-74AEFF8CA350}
There are also other non etching products that might work well for you. I have used the 600 detergent on new construction glass block but diluted the detergent with more water than usual. With any of the products that need to be diluted with water I would gradually add detergent to the water and use as little as possible. Since you are taking apart the wall, do all of the cleaning outside and keep away from skin contact.
NJ Brickie is offline
Old 02-21-2009, 11:24 PM   #4
stonelayer's Avatar
Trade: stone mason
viniger breaks down lime. It does take time but will work and is cost effective.
stonelayer is offline
Old 02-22-2009, 12:09 AM   #5
Tscarborough's Avatar
No matter what you use, if it takes you more than 15 minutes per block you are losing money.
Tscarborough is offline
Old 02-22-2009, 09:38 AM   #6
stacker's Avatar
Trade: masonry
the best product to clean mortar off glass block is EG.............elbow grease.
muratic acid will help loosen the older mortar.
but i agree with tscar,if it takes you too long your pissing in the wind.
stacker is offline
Old 02-22-2009, 10:32 AM   #7
Acid will etch the glass, BTW.
Old 02-22-2009, 10:49 AM   #8
tkle's Avatar
2006 IBC 2103.6 Glass unit masonry
Reclaimed units shall not be used.
I've done a lot of showers using mortar.No problems.
tkle is offline
Old 02-22-2009, 03:32 PM   #9
NJ Brickie's Avatar
Trade: Bricklayer
I wonder what the reasoning behind not using reclaimed glass block is? As long as the block is not cracked or chipped. The only reason I could see is, if there was a call for a specialty block like bulletproof and you needed to know exactly what you are getting.
Old 02-22-2009, 06:43 PM   #10
stacker's Avatar
Trade: masonry
i have never had muratic acid etch glass.im not calling you a liar,but ive never had that problem.when i acidize a house i always wash the windows down to remove any mud still on them.im not using straight acid tho.
stacker is offline
Old 02-22-2009, 07:03 PM   #11
Error Corrector
olyteddy's Avatar
Trade: Maintenance Manager
Yeah, Muriatic, which is 28% Hydrochloric Acid, should be glass safe (it's commonly stored in glass). Hydroflouric acid is used to etch glass.
olyteddy is offline
Old 02-23-2009, 12:57 AM   #12
Nobreus's Avatar
Thank you all, greatly appreciate all the experience.
Nobreus is offline
Old 02-23-2009, 06:09 AM   #13
CJKarl's Avatar
Trade: Masonry
What he said.
There's Always A Market For Quality
http://www.kaufmannmasonry.com/
CJKarl is offline
Old 02-23-2009, 10:15 AM   #14
Well, muriatic doesn't etch glass block.
Old 02-23-2009, 12:35 PM   #15
Super B
skyhook's Avatar
Originally Posted by Nobreus View Post
I need to take apart an existing shower wall, 7 feet by 8 feet long, because the first installer used mortar instead of silicone, ? And also if anybody has experience with using silicone for such a large wall?
Sounds like the beginning of a tanglef**k.
skyhook is offline
Old 02-23-2009, 01:38 PM   #16
tkle's Avatar
I did my shower with reclaimed GB. Soaked them first for about a week in a strong solution of muratic and water. No problem. I'm glad Stacker said something because I hate to question you. You're usually right.
tkle is offline
Old 02-23-2009, 02:05 PM   #17
I am always wrong, just ask my wife.
Old 02-23-2009, 05:23 PM   #18
CJKarl's Avatar
Trade: Masonry
I was never big on the silicone block system. I've seen completed walls, but never did one.
The only drawback with used block is the nice coating of bonding agent applied at the factory (Owens-Corning anyways) and I think I used a German block once that had it. Don't use silicone, use glass block mortar and FILL your joints completely.
CJKarl is offline
Old 03-04-2009, 01:25 AM   #19
Nobreus's Avatar
Cjkarl, thanks for your input, the owners wanted silicone when the original installer built the shower enclosure, but he used mortar instead, and now the owners want to re-do the enclosure because it sagged and bowed, (it's a big wall), and i am looking at bidding the job. the question i have is if the mortar comes in clear? which i don't think it does, and if silicone would work as well as mortar if i use the metal support system?
Nobreus is offline
Old 09-08-2009, 06:05 PM   #20
taylen's Avatar
Trade: general
Tscarboroug, are we married to the woman? My wife always says I am wrong also.
taylen is offline
Glass block shower wall Soul-tez Kitchens & Baths 9 03-27-2011 10:22 AM
Glass Block Paulie Remodeling 27 03-23-2009 02:30 PM
Glass Block 411 andeeznuts Remodeling 14 01-22-2009 08:17 PM
Glass Block Transition Paul_NJ Ceramic & Stone Tile 0 03-15-2007 08:14 AM
glass block entry to shower Mr. D Masonry 10 12-04-2006 02:14 PM
